[Nek5000-users] turbChannel compiling issue after adding more elements
    nek5000-users at lists.mcs.anl.gov
    Thu Jan 25 11:04:30 CST 2018
Hello,
Thank you all for your suggestions. However they did not really work either. The current work on the turbulent channel is in fact based on the original turbChannel in the example. The current lelg number is the actual number of elements (73728) I used. I also tried to increase the lelg a bit to 73750, which did not make any difference. I decreased lpmin from 4 to 2 and unfortunately this did not work either. I wonder if there is any actual limitation to the number of elements that shall be used provided the physical dimentions defined in the code (2 pi delta * pi delta * 2 delta).
Thank you all for your time and suggestions!
Ming
URL: <http://lists.mcs.anl.gov/pipermail/nek5000-users/attachments/20180125/43ac6ca9/attachment.html>
More information about the Nek5000-users
