[Nek5000-users] Compiling large problem sizes
Mon Dec 4 13:53:08 CST 2017
Hi all,
I'm trying to compile a 3D mesh with mesh size of 6000 ekements.
Unfortunately I keep running into compilation errors. To be clear I can
compile problems upto 3000 elements large. But setting lelt value larger
than 3000 results in an error.
I have realised this might be a memory issue and have tried to compile with
increasing amounts of available memory. This does not seem to resolve the
issue.
To be clear my SIZE looks like this
 parameter (ldim=3)               ! domain dimension (2 or 3)
      parameter (lx1=6)                ! p-order (avoid uneven and values
<6)
      parameter (lxd=10)               ! p-order for over-integration
(dealiasing)
      parameter (lx2=lx1-2)            ! p-order for pressure (lx1 or lx1-2)
      parameter (lelg=6000)             ! max total number of elements
      parameter (lpmin=1)              ! min MPI ranks
      parameter (lpmax=1024)           ! max MPI ranks
      parameter (ldimt=1)              ! max auxiliary fields (temperature
+ scalars)
Sincerely,
*Amitvikram Dutta*
Graduate Research Assistant
Fluid Mechanics Research Lab
University of Waterloo
URL: <http://lists.mcs.anl.gov/pipermail/nek5000-users/attachments/20171204/253a32ea/attachment.html>
