[Nek5000-users] Error Compiling
Wed Nov 16 18:48:10 CST 2016
I tried and I got "command not found".
I copied visnek from /bin and paste at the eddy folder, is that right?
2016-11-16 15:16 GMT-02:00 <nek5000-users at lists.mcs.anl.gov>:
> Try ‘visnek eddy_uv’ without the ‘./'
> On Nov 16, 2016, at 11:41 AM, nek5000-users at lists.mcs.anl.gov wrote:
> Thanks for the answer.
> I tried to use visnek. After type ./visnek eddy_uv I got these error:
> bash: ./visnek: /bin/tcsh: bad interpreter: No such file or directory
> Any ideia?
> Mateus.
> 2016-11-16 14:34 GMT-02:00 <nek5000-users at lists.mcs.anl.gov>:
>> I think you can ignore the error message you are getting.
>> As for visualization of the solution, you can also use visit or paraview.
>> You have to use visnek.
>> Marco
>> On Nov 16, 2016, at 11:12 AM, nek5000-users at lists.mcs.anl.gov wrote:
>> I realize my mistake. My PATH was wrong, now I can compile without
>> problems.
>> But now I have other problem. After compile with makenek and after run
>> with nekb I can't vizualize the results with postx.
>> My path is /bin, I type ./postx and I got a black window without a
>> sidebar.
>> Whats wrong?
>> Thanks.
>> 2016-11-16 1:11 GMT-02:00 <nek5000-users at lists.mcs.anl.gov>:
>>> What does echo $PATH return for you?
>>> On Nov 15, 2016, at 4:31 PM, nek5000-users at lists.mcs.anl.gov wrote:
>>> Hi all,
>>> I'm ver new at nek5000. I'm trying to compiling a first example case
>>> (eddy) and I get a error.
>>> After ./makenek eddy_uv
>>> I get:
>>> ./makenek: line 92: /home/mateus/nek5000/core/makenek.inc: No such file
>>> or directory
>>> make: makefile: No such file or directory
>>> make: *** No rule to make target 'makefile'.  Stop.
>>> Can someone help me?
>>> Mateus Peixoto Avanci
>>> Engenheiro Mecânico
>>> Aluno do Programa de Pós-Graduação em Engenharia Mecânica
>>> Universidade Federal Fluminense
>>> *http://lattes.cnpq.br/1773896725783894
>>> <http://lattes.cnpq.br/1773896725783894>*
>>> _______________________________________________
>>> Nek5000-users mailing list
>>> Nek5000-users at lists.mcs.anl.gov
>>> https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users
>> Engenheiro Mecânico
> Engenheiro Mecânico
Engenheiro Mecânico
URL: <http://lists.mcs.anl.gov/pipermail/nek5000-users/attachments/20161116/751c2012/attachment-0001.html>
