[Nek5000-users] MOAB Cubit problem
nek5000-users at lists.mcs.anl.gov
Wed Apr 29 11:47:22 CDT 2015
Hi,I use Trelis (V 15) to generate mesh. However, when I try to use mbconvert to generate h5m file, it says
[0]MOAB ERROR: --------------------- Error Message ------------------------------------[0]MOAB ERROR: This doesn't appear to be a .cub file![0]MOAB ERROR: load_file() line 310 in src/io/Tqdcfr.cpp[0]MOAB ERROR: --------------------- Error Message ------------------------------------[0]MOAB ERROR: Failed to load file after trying all possible readers![0]MOAB ERROR: serial_load_file() line 634 in src/Core.cpp[0]MOAB ERROR: load_file() line 523 in src/Core.cppFailed to load "/home/hamid/nek5_svn/moab_conjht/cubit01.cub".Error code: MB_FAILURE (16)Error message: Failed to load file after trying all possible readers
I have downloaded other cub files from repository and mbconvert works fine on them. However opening and saving these files with Trelis causes same problem.I think the file format in Trelis is different than Cubit. Is it true? if yes what is the solution?
Hamid
URL: <http://lists.mcs.anl.gov/pipermail/nek5000-users/attachments/20150429/1b3f277b/attachment.html>
More information about the Nek5000-users
