[Nek5000-users] Saving perturbation solution
Thu Sep 25 23:06:17 CDT 2014
Dear neks
I am still stuck with the problem of not being able to save the
perturbation solution using out_pert(). Do you have any suggestions ?
Thanks
praveen
On Tue, Sep 9, 2014 at 6:57 PM, <nek5000-users at lists.mcs.anl.gov> wrote:
> Hello neks
> I am running the perturbation code by modifying the os7000 example. The
> code runs. But if I try to save the perturbation solution like this
>        ifxyo = .false.
>        if(istep.eq.0)then
>           ifxyo = .true.
>           call out_pert()
>        else if(mod(istep,iostep).eq.0)then
>           call out_pert()
>        endif
> then I get the crash
>          1 U-PRES gmres:     25  3.8311E-12  5.0000E-12  1.6258E-08
> 3.7787E-03  1.1255E-02
> filt amp 0.0000 0.0000 0.0000 0.0000 0.0000 0.0000 0.0000 0.0000 0.0000
> 0.0000 0.0000 0.0000 0.0000 0.0500
> filt trn 1.0000 1.0000 1.0000 1.0000 1.0000 1.0000 1.0000 1.0000 1.0000
> 1.0000 1.0000 1.0000 1.0000 0.9500
>  2.000000E-03     1  1.78124472E-03  1.78124472E-03  1.00000713E+00
> 1.00000686E+00  2.63413513E-07  3.83894325E-02 egn
> Program received signal SIGFPE: Floating-point exception - erroneous
> arithmetic operation.
> Backtrace for this error:
> #0  0x10fa6770d
> #1  0x10fa67c1b
> #2  0x7fff872745a9
> #3  0x1042ad8fe
> #4  0x1042aeafb
> #5  0x1044e705c
> Thanks
> praveen
> Nek5000-users mailing list
URL: <http://lists.mcs.anl.gov/pipermail/nek5000-users/attachments/20140926/856a97b0/attachment.html>
