[Nek5000-users] Problem in 2d pipe simulation
Mon Jan 13 13:03:54 CST 2014
Thanks a lot.
Could you please tell me where I can find more information of defining the .usr file.
for example if I have boundary condition like this on a pipe
" v,O,W,W  "
and If I want to define a parabolic profile on the inlet say a value of 10 . How do I specific the edge ?
Thank you.
Kamal
On Jan 13, 2014, at 7:58 PM, nek5000-users at lists.mcs.anl.gov wrote:
> Hi,
> When you create the .box file, it is important that the line containing the boundary conditions follows the format as described on the nek wiki and documentation.
> It is a 3 character code that defines each boundary condition, and the whitespace must be maintained.  For example,
> "v  ,A  ,W  ,W  ,   ,   "
> would be a valid entry, whereas using less than 3 characters will result in commas and whitespace being entered into your .rea file.
> More info and examples can be found:
> http://nek5000.mcs.anl.gov/index.php/Genbox
> Best,
> Katie
> On Mon, Jan 13, 2014 at 8:49 AM, <nek5000-users at lists.mcs.anl.gov> wrote:
> Hi,
> I created my .box file, with help of genbox I created .rea file.
> later I created a .usr and SIZE file.
> I have attached all the files I used with this mail
> I launched the simulation and I got this error
> |      _   __ ______ __ __  ______  ____    ____    ____   |
> |     / | / // ____// //_/ / ____/ / __ \\ / __ \\ / __ \\ |
> |    /  |/ // __/  / ,<   /___ \\  / / / // / / // / / /   |
> |   / /|  // /___ / /| | ____/ / / /_/ // /_/ // /_/ /     |
> |  /_/ |_//_____//_/ |_|/_____/  \\____/ \\____/ \\____/   |
> | NEK5000:  Open Source Spectral Element Solver            |
> | COPYRIGHT (c) 2008-2010 UCHICAGO ARGONNE, LLC            |
> | Version:  1.0rc1 / SVN  r982                             |
> | Web:      http://nek5000.mcs.anl.gov                     |
>  Number of processors:           1
>  REAL    wdsize      :           8
>  INTEGER wdsize      :           4
>   Beginning session:
> /home/kamal/neksamples/mine/box.rea
>  timer accuracy:   0.0000000E+00 sec
>  read .rea file
>  nelgt/nelgv/lelt:          15          15          15
>  lx1  /lx2  /lx3 :           8           6           8
>  mapping elements to processors
>            0          15          15          15          15  NELV
>  RANK     0 IEG       1       2       3       4       5 6       7       8
>                       9      10      11      12      13      14 15
>  element load imbalance:            0          15          15
>  done :: mapping elements to processors
>            0  objects found
>  done :: read .rea file   0.67091E-03 sec
>  Reset the target Courant number to .5
>  setup mesh topology
>    Right-handed check complete for      15 elements. OK.
>    setvert2d:   8         252         792         252         252
>  call usrsetvert
>  done :: usrsetvert
> gs_setup: 0 unique labels shared
>    handle bytes (avg, min, max): 3972 3972 3972
>    buffer bytes (avg, min, max): 0 0 0
>    setupds time 1.9503E-04 seconds   0  8         252          15
>            4  max multiplicity
>  done :: setup mesh topology
>  call usrdat
>  done :: usrdat
>  generate geometry data
>  vol_t,vol_v:   1.9999999999999920        1.9999999999999920
>  done :: generate geometry data
>  call usrdat2
>  done :: usrdat2
>  regenerate geometry data           1
>  vol_t,vol_v:   1.9999999999999938        1.9999999999999938
>  done :: regenerate geometry data           1
>  verify mesh topology
>    0.0000000000000000        4.0000000000000000       Xrange
>    0.0000000000000000       0.50000000000000000       Yrange
>    0.0000000000000000        0.0000000000000000       Zrange
>  done :: verify mesh topology
>  103   Parameters from file:/home/kamal/neksamples/mine/box.rea
>    1      1.00000         p1  DENSITY
>    2     -20.0000         p2  VISCOS
>    7      1.00000         p7  RHOCP
>    8      1.00000         p8  CONDUCT
>   11      1000.0          p11 NSTEPS
>   12     -1.000000E-04    p12 DT
>   15      100.000         p15 IOSTEP
>   18      0.250000E-01    p18 GRID
>   19     -1.00000         p19 INTYPE
>   20      12.0000         p20 NORDER
>   21      0.100000E-10    p21 DIVERGENCE
>   22      0.100000E-11    p22 HELMHOLTZ
>   24      0.100000E-09    p24 TOLREL
>   25      0.100000E-09    p25 TOLABS
>   26      1.00000         p26 COURANT/NTAU
>   27      3.00000         p27 TORDER
>   28      0.              p28 TORDER: mesh velocity (0: p28=p27)
>   43      1.00000         p43 0=semg/1=schwarz
>   66      4.00000         p66 output : <0=ascii, else binary
>   67      4.00000         p67 restart: <0=ascii, else binary
>   93      20.0000          p93 Number of previous pressure solns saved
>   94      5.00000          p94 start projecting velocity after p94 step
>   95      5.00000          p95 start projecting pressure after p95 step
>   96      1.00000          p96 u0 translational velocity (in .usr)
>   97      0.30000          p97 v0 translational velocity (in .usr)
>   99      3.00000          p99   dealiasing: <0--> off/3--> old/4--> new
>  102      1.00000          p102   Dump out divergence at each time step
>  IFTRAN   = T
>  IFFLOW   = T
>  IFHEAT   = F
>  IFSPLIT  = F
>  IFLOMACH = F
>  IFUSERVP = F
>  IFUSERMV = F
>  IFSTRS   = F
>  IFCHAR   = F
>  IFCYCLIC = F
>  IFAXIS   = F
>  IFMVBD   = F
>  IFMELT   = F
>  IFMODEL  = F
>  IFKEPS   = F
>  IFMOAB   = F
>  IFNEKNEK = F
>  IFSYNC   = T
>  IFVCOR   = T
>  IFINTQ   = F
>  IFCWUZ   = F
>  IFSWALL  = F
>  IFGEOM   = F
>  IFSURT   = F
>  IFWCNO   = F
>  IFTMSH for field           1    =  F
>  IFADVC for field           1    =  T
>  IFNONL for field           1    =  F
>  Dealiasing enabled, lxd=          12
>  Estimated eigenvalues
>  EIGAA =    20.047633939712757
>  EIGGA =    46987.971345031350
>  EIGAE =   0.61685027506808487
>  EIGAS =    3.8461538461538464E-003
>  EIGGE =    46987.971345031350
>  EIGGS =    2.0000000000000000
>   E-solver strategy:  1 itr
>            0          15  BC FAIL
> EXIT: E INVALID BC FOUND in genfast         15
> call exitt: dying ...
> backtrace(): obtained 9 stack frames.
> ./nek5000(print_stack_+0x1a) [0x4fe90a]
> ./nek5000(exitt_+0x20f) [0x5bc0af]
> ./nek5000(exitti_+0x12a) [0x5be72a]
> ./nek5000(gen_fast_+0x581) [0x4fa701]
> ./nek5000(set_overlap_+0x125) [0x4eb465]
> ./nek5000(nek_init_+0x82d) [0x41affd]
> ./nek5000(main+0x24) [0x419e54]
> /lib/x86_64-linux-gnu/libc.so.6(__libc_start_main+0xf5) [0x7fd9f1f33de5]
> ./nek5000() [0x419e99]
> total elapsed time             :   3.74889E-03 sec
> total solver time incl. I/O    :   0.00000E+00 sec
> time/timestep                  :   0.00000E+00 sec
> CPU seconds/timestep/gridpt    :   0.00000E+00 sec
> real    0m0.030s
> user    0m0.020s
> sys    0m0.000s
> Nek5000-users mailing list
URL: <http://lists.mcs.anl.gov/pipermail/nek5000-users/attachments/20140113/055bb78e/attachment-0001.html>
