[Nek5000-users] Error when running the vortex problem
nek5000-users at lists.mcs.anl.gov
Tue Oct 11 16:47:56 CDT 2011
Shouldn't it be param(67)?
Justin
On Tue, Oct 11, 2011 at 2:03 PM, <nek5000-users at lists.mcs.anl.gov> wrote:
> Hi Dong,
> For some reason, your run is traversing the .f00000 file format
> branch, rather than the .fld input branch.
> This traversal is generally controlled by setting param(66)=4 (for .fld) in
> usrdat2 (or usrdat) in the .usr file.
> I'm wondering if you are compiling with r1854.usr provided in
> the examples/vortex directory?
> Paul
> On Tue, 11 Oct 2011, nek5000-users at lists.mcs.anl.**gov<nek5000-users at lists.mcs.anl.gov>wrote:
>> Hi Dong,
>> What kind of platform are you running on?
>> Can you do an svn update in the example directory, just in case
>> the file was contaminated on transfer?
>> Paul
>> Hi, Stefan.
>>> Sure. Attached is the log file.
>>> -Dong
>>> -----Original Message-----
>>> From: nek5000-users-bounces at lists.**mcs.anl.gov<nek5000-users-bounces at lists.mcs.anl.gov>[mailto:
>>> nek5000-users-bounces@**lists.mcs.anl.gov<nek5000-users-bounces at lists.mcs.anl.gov>]
>>> On Behalf Of nek5000-users at lists.mcs.anl.**gov<nek5000-users at lists.mcs.anl.gov>
>>> Sent: Tuesday, October 11, 2011 2:15 PM
>>> To: nek5000-users at lists.mcs.anl.**gov <nek5000-users at lists.mcs.anl.gov>
>>> Subject: Re: [Nek5000-users] Error when running the vortex problem
>>> Please post a full log file. Note the file size is limited to 100KB.
>>> -Stefan
>>> On 10/11/11, S K <stgeke at googlemail.com> wrote:
>>>> Hi Dong,
>>>> It works for me. Did you change anything?
>>>> -Stefan
>>>> On 10/11/11, nek5000-users at lists.mcs.anl.**gov<nek5000-users at lists.mcs.anl.gov>
>>>> <nek5000-users at lists.mcs.anl.**gov <nek5000-users at lists.mcs.anl.gov>>
>>>> wrote:
>>>>> Hi,
>>>>> I was trying to run nek5000 with vortex, following the default user
>>>>> setting.
>>>>> There is no problem for building, however when I start to run the
>>>>> application, there is an error "NONSTD HDR, parse_hdr, abort". The
>>>>> following
>>>>> is the related error report.
>>>>> Reading checkpoint data
>>>>> 0 0 OPEN: r1492_n08.fld27
>>>>> byte swap: T 0.000000 0.000000
>>>>> 140 8 8 8 5.0101000E+0250101 U P 4
>>>>> NELT,NX,N
>>>>> úaÃ@^@^@^@^@^@^@^@^@^@^@^@^@^**@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^**
>>>>> NONSTD HDR, parse_hdr, abort.
>>>>> I briefly read the code. It looks like the code is reading the
>>>>> checkpoint
>>>>> file "r1492_n08.fld27" and there is something wrong with the file
>>>>> header.
>>>>> The file header does not follow the standard format and the code cannot
>>>>> understand the file.
>>>>> How can I solve this problem?
>>>>> Thank you.
>>>>> -Dong
>>>> ______________________________**_________________
>>> Nek5000-users mailing list
>>> Nek5000-users at lists.mcs.anl.**gov <Nek5000-users at lists.mcs.anl.gov>
>>> https://lists.mcs.anl.gov/**mailman/listinfo/nek5000-users<https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users>
> Hi, Stefan.
>> -Dong
>> -Stefan
>>> Hi Dong,
>>> -Stefan
>>> wrote:
>>>> Hi,
>>>> setting.
>>>> following
>>>> NELT,NX,N
>>>> checkpoint
>>>> header.
>>>> Thank you.
>>>> -Dong
URL: <http://lists.mcs.anl.gov/pipermail/nek5000-users/attachments/20111011/ad803217/attachment.html>
More information about the Nek5000-users
