[Nek5000-users] Laplacian as a forcing function and stability issues
nek5000-users at lists.mcs.anl.gov
Thu Nov 4 14:20:19 CDT 2010
I am trying to implement a LES model which requires a term like c . Sij* to
be added to the existing unfiltered viscous term. I am computing Sij* by
filtering the velocity and calling comp_gije() twice. This is then included
in the forcing function. This seems to work for few steps but the solution
starts to blow up afterwards. I am wondering if this would be due to
stability issues since the laplacian here is not calculated by any of the
splitting methods. I would like to know if it would be possible to add this
term to the Navier Stokes formulation that is solved each step. Any other
ideas/ thoughts would be helpful. Thanks.
Regards
Shriram
URL: <http://lists.mcs.anl.gov/pipermail/nek5000-users/attachments/20101104/c89b57f0/attachment.html>
More information about the Nek5000-users
