[Nek5000-users] Segmentation fault occuerd
Mon Feb 15 09:45:19 CST 2010
Hello,
I have some trouble to run my simulation... When I start running my
simulation, I receive the following error-message (I compiled the run
in debugging mode -g and with traceback):
forrtl: severe (174): SIGSEGV, segmentation fault occurred
Image              PC                Routine            Line
Source             libc.so.6          00002B76C2128FA0  Unknown
       Unknown  Unknown
nek5000            0000000000500D48  chcopy_                   434  math.f
nek5000            000000000071BA91  exitti_                   399  comm_mpi.f
nek5000            0000000000565F6A  set_conv_char_            603  convect.f
nek5000            0000000000561C80  setup_convect_             44  convect.f
nek5000            00000000004E805C  setics_                   393  ic.f
nek5000            0000000000417B2A  nek_init_                 164  drive1.f
nek5000            0000000000415FCD  MAIN__                     26  drive.f
nek5000            0000000000415F8C  Unknown               Unknown  Unknown
libc.so.6          00002B76C20D14CA  Unknown               Unknown  Unknown
nek5000            0000000000415EBA  Unknown               Unknown  Unknown
mpirun has exited due to process rank 0 with PID 10816 on
node ifh-taifun exiting without calling "finalize". This may
have caused other processes in the application to be
terminated by signals sent by mpirun (as reported here).
By debbuging I've seen, that follwoing values in the subroutine
set_conv_char (in convect.f) seem to be a little strange:
nxd=           0
nyd=     7457184
nzd=           0
In my DEALIAS-file the follwing line is commented out:
C      common /dedim/ nxd,nyd,nzd
I tried to run the simulation with the declaration in the DEALIAS-file
and a      include 'DEALIAS'
in the subroutine set_conv_char (in convect.f) but the the run also is dying:
   ZWGJD: Minimum number of Gauss points is 1 -1633391248
  call exitt: dying ...
Do you maybe know where there might be my buck??
Thx a lot.
Fred
Here my SIZEu-file:
C     Dimension file to be included
C
C     HCUBE array dimensions
C
      PARAMETER (LDIM=3)
      PARAMETER (LX1=6,LY1=6,LZ1=6,LELT=4420,LELV=4420)
      parameter (lxd=9,lyd=lxd,lzd=lxd)
      parameter (lelx=6,lely=lelx,lelz=lelx)
      PARAMETER (LZL=3)
      PARAMETER (LX2=LX1-2)
      PARAMETER (LY2=LY1-2)
      PARAMETER (LZ2=LZ1-2)
      PARAMETER (LX3=LX1)
      PARAMETER (LY3=LY1)
      PARAMETER (LZ3=LZ1)
      parameter (lpelv=1,lpelt=1,lpert=1)        ! perturbation
      parameter (lpx1=1,lpy1=1,lpz1=1)           ! array sizes
      parameter (lpx2=1,lpy2=1,lpz2=1)
      parameter (lbelv=1,lbelt=1)                ! MHD
      parameter (lbx1=1,lby1=1,lbz1=1)           ! array sizes
      parameter (lbx2=1,lby2=1,lbz2=1)
C LX1M=LX1 when there are moving meshes; =1 otherwise
      PARAMETER (LX1M=1,LY1M=1,LZ1M=1)
      PARAMETER (LDIMT= 1)
c     PARAMETER (LDIMT= 3)
      PARAMETER (LDIMT1=LDIMT+1)
      PARAMETER (LDIMT3=LDIMT+3)
      PARAMETER (LP = 8)
      PARAMETER (LELG   = LP*LELT)
c
c
c     Note:  In the new code, LELGEC should be about sqrt(LELG)
c
      PARAMETER (LELGEC = 1)
      PARAMETER (LXYZ2  = 1)
      PARAMETER (LXZ21  = 1)
c
      PARAMETER (LMAXV=LX1*LY1*LZ1*LELV)
      PARAMETER (LMAXT=LX1*LY1*LZ1*LELT)
      PARAMETER (LMAXP=LX2*LY2*LZ2*LELV)
      PARAMETER (LXZ=LX1*LZ1)
      PARAMETER (LORDER=3)
C FF      PARAMETER (MAXOBJ=2,MAXMBR=LELT*6)
      PARAMETER (MAXOBJ=4,MAXMBR=LELT*6,lhis=100)
C
C     Common Block Dimensions
C
      PARAMETER (LCTMP0 =2*LX1*LY1*LZ1*LELT)
      PARAMETER (LCTMP1 =4*LX1*LY1*LZ1*LELT)
C
C     The parameter LVEC controls whether an additional 42 field arrays
C     are required for Steady State Solutions.  If you are not using
C     Steady State, it is recommended that LVEC=1.
C
      PARAMETER (LVEC=1)
C
C     Uzawa projection array dimensions
C
C FF      PARAMETER (MXPREV = 10)
      parameter (mxprev = 20)
      parameter (lgmres = 40)
C
C     Split projection array dimensions
C
      parameter(lmvec = 1)
      parameter(lsvec = 1)
      parameter(lstore=lmvec*lsvec)
c
c     NONCONFORMING STUFF
c
      parameter (maxmor = lelt)
C
C     Array dimensions
C
      COMMON/DIMN/NELV,NELT,NX1,NY1,NZ1,NX2,NY2,NZ2
     $,NX3,NY3,NZ3,NDIM,NFIELD,NID
c automatically added by makenek
      parameter(lxo   = lx1) ! max output grid size (lxo>=lx1)
      parameter(lpart = 1  ) ! max number of particles
      integer ax1,ay1,az1,ax2,ay2,az2
      parameter (ax1=lx1,ay1=ly1,az1=lz1,ax2=lx2,ay2=ly2,az2=lz2) !
running averages
