[mpich2-dev] Cartesian space process topology
Lukáš Pavlech
pavlech.lukas at gmail.com
Mon Oct 22 07:37:53 CDT 2012
Hello,
As a part of my Master Thesis, I am currently working on some agent
simulations in fire buildings using Repast HPC. Repast HPC use MPI inteface
for process communication - in my case MPICH2 implementation. At simulation
start space is divided to processes using MPI_Cart_create and
MPI_Cart_shift commands.
Specifically:
boost::mpi::communicator commM;
int _numDims = 2; (kedže sa jedná o 2D priestor)
(kde dany priestor je periodicky)
int* periods = new int[_numDims];
for (int i = 0; i < _numDims; i++) {
periods[i] = periodic ? 1 : 0;
MPI_Comm topology_comm;
*MPI_Cart_create(*commM, _numDims, &procsPerDim[0], periods, 0,
&topology_comm);*
int eRank, wRank, nRank, sRank;
*MPI_Cart_shift(topology_comm, 1, 1, &wRank, &eRank);
MPI_Cart_shift(topology_comm, 0, -1, &sRank, &nRank);*
After successfull run of these commands, will be the topology structure the
same as the structure in attached image?
Thanks in advance
Best Regards
Lukas Pavlech
URL: <http://lists.mcs.anl.gov/pipermail/mpich2-dev/attachments/20121022/a6ca2e9b/attachment.html>
Type: image/gif
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/mpich2-dev/attachments/20121022/a6ca2e9b/attachment.gif>
More information about the mpich2-dev
