[mpich2-dev] question about communication optimization on shared memory
Shigang Li shigangli.cs at gmail.com
Tue Oct 16 15:27:36 CDT 2012
OK, thank you.
On Tue, Oct 16, 2012 at 2:22 PM, Darius Buntinas <buntinas at mcs.anl.gov>wrote:
> You can control it with --with-shared-memory[=auto|sysv|mmap].  You can
> check which is being used by looking at the configure output (look for
> "Using a memory-mapped file for shared memory" or "Using SYSV shared
> memory").
> -d
> On Oct 16, 2012, at 3:11 PM, Shigang Li wrote:
> > Hi,Darius,
> > Thank you and this really makes sense. I still have one question. Is it
> possible for a MPICH programmer to know which configuration is using, e.g.
> posix shared memory,  sys V shared memory or disabled?
> > Best Regards,
> > Shigang.
> > On Mon, Oct 15, 2012 at 10:18 AM, Darius Buntinas <buntinas at mcs.anl.gov>
> wrote:
> > MPICH configure will try to use posix shared memory (i.e., mmapping a
> file), and if that fails it will try to use sysv shared memory (i.e.,
> shmat).  If that fails, I think configure aborts (but it may just disable
> shared memory, I'm not sure).  Sysv shared memory typically has tight
> limits on the amount of shared memory that can be allocated per process and
> per node, so you don't really want to use that.
> > At init time, the processes query the process manager for the topology
> (i.e., which processes are on which nodes), and based on that decide which
> pairs of processes should communicate using shared memory and which should
> use the network.
> > Currently collectives are implemented using point-to-point messages, so
> some messages will go over shared memory and some over the network.  The
> communication patterns used by the collectives are optimized to take the
> topology into account.  MPICH does have an interface to allow implementors
> to override the default collective algorithms, such as using shared memory,
> but we haven't done this yet.
> > -d
> > On Oct 14, 2012, at 8:31 PM, Shigang Li wrote:
> > > Dear Sir or Madam,
> > > I'm a student from UIUC, and have some questions about communication
> optimizations on shared memory in state-of-art mpich2.
> > > 1) When configure mpich2, does it support shared memory optimization
> in default? If so, can it select the communication pattern automatically
> according to hardware architecture? For example in a SMPs cluster, using
> shared memory optimization within a node and using socket cross nodes?
> > > 2) What about collective communication on shared memory? Is it
> implemented on top of the optimized point to point communication or use
> other mechanisms?
> > > Best Regards,
> > > Shigang.
URL: <http://lists.mcs.anl.gov/pipermail/mpich2-dev/attachments/20121016/6e6143a9/attachment.html>
More information about the mpich2-dev mailing list
