[mpich2-dev] No Gain For calculating maximum of an array
Aman Madaan madaan.amanmadaan at gmail.com
Fri Nov 9 13:28:55 CST 2012
Thanks a lot for the answers!
I have calculated the maximum element of an array that has around 5*10^7
elements, but there were still no gains!
Is the code correct?
I have reattached the program file for your kind reference.
I would like to request some more guidance on the results.
As i mentioned, the results that i get from embarrassingly parallel
problems are not at all surprising .
The plots are (
https://github.com/madaan/BVP-MPI-PROJECT/blob/master/PI/PI.png) and (
https://github.com/madaan/BVP-MPI-PROJECT/blob/master/SumNELe/Sigma%28N%29.png)
The setup is as follows :
*Node configuration*
There are 3 similar nodes, each consisting of an Intel(R) Pentium(R) 4 CPU,
2.60GHz with 512 MB of memory. Each processor has 512 KB cache.
 Another node has an Intel Core i3-330M, 2.13GHz with 3GB of memory. It is
termed *FOX* for reference . All the nodes runs Ubuntu 12.04 Long term
support version.
*Network setup:*
Nodes are interconnected via a fast Ethernet switch (10 MB/s). The network
configuration is essentially meshed. For all tests the MPI/Pro library from
MPI Software Technology (MPI/Pro distribution version 1.6.3).
The aim of the project is to compare the computing power of a group of
dumped machines  with a state of the art ( or so i say ) computer, called
the fox for reference.
We call the project *Junk Computing*.
I request your thoughts /comments /criticism .
I also request suggestions for some simple benchmarking programs that i can
write.
Thanks for the precious time.
With regards
On Fri, Nov 9, 2012 at 11:30 PM, <mpich2-dev-request at mcs.anl.gov> wrote:
> Send mpich2-dev mailing list submissions to
>         mpich2-dev at mcs.anl.gov
> To subscribe or unsubscribe via the World Wide Web, visit
>         https://lists.mcs.anl.gov/mailman/listinfo/mpich2-dev
> or, via email, send a message with subject or body 'help' to
> You can reach the person managing the list at
>         mpich2-dev-owner at mcs.anl.gov
> When replying, please edit your Subject line so it is more specific
> than "Re: Contents of mpich2-dev digest..."
> Today's Topics:
>    1. Re:  mpich2-dev Digest, Vol 47, Issue 3
>       (Muhammad Zulfikar Handana)
>    2.  No Gain For calculating maximum of an array (Aman Madaan)
>    3. Re:  No Gain For calculating maximum of an array (Jeff Hammond)
> Message: 1
> Date: Fri, 9 Nov 2012 14:28:04 +0700
> From: Muhammad Zulfikar Handana <zulfikarhandana at gmail.com>
> To: mpich2-dev at mcs.anl.gov
> Subject: Re: [mpich2-dev] mpich2-dev Digest, Vol 47, Issue 3
> Message-ID:
>         <CAN0Ct=3J9cmmDeXY96qcoJW+iLQvc705QuxWuW=
> rGYeSPv1+Ug at mail.gmail.com>
> Content-Type: text/plain; charset="iso-8859-1"
> Thanks jeff for your answer and i have another question
>  so thats mean, MPICH2 must be modified before we have setting manually
> that message protocol?
> Thanks
> Handana
> > Message: 4
> > Date: Mon, 5 Nov 2012 23:18:11 -0500
> > From: Jeff Hammond <jhammond at alcf.anl.gov>
> > Subject: Re: [mpich2-dev] setting manually eager to rendezvous
> > Message-ID:
> >         <CAGKz=uKP2D0mut=
> > P92SLR6D00A_9n6KcJWO8fqFppiotYfDz3g at mail.gmail.com>
> > Content-Type: text/plain; charset=ISO-8859-1
> > Please post user questions to mpich-discuss at mcs.anl.gov.  This list is
> > for developers of MPICH2 and those who may be modifying the
> > implementation.
> > In this case, those environment variables are not relevant unless you
> > have Blue Gene/P, and in that case, MPICH2 1.4 will not work anyways.
> > If you want to know about eager vs. rendezvous, perhaps you can
> > re-post this question on the user list and someone will answer
> > regarding the settings for ch3.
> > Best,
> > Jeff
> > On Mon, Nov 5, 2012 at 10:46 PM, Muhammad Zulfikar Handana
> > <zulfikarhandana at gmail.com> wrote:
> > > Hi, iam Handana. this my first project using MPICH2, i have little
> > confused
> > > because i dont know how to setting manually eager to rendezvous at
> MPICH2
> > > 1.41p1. i have a read this using code
> > > DCMF_EAGER -
> > > DCMF_RZV -
> > > am i right? or there is another code? thank you very much for your
> > attention
> > Jeff Hammond
> > Argonne Leadership Computing Facility
> > University of Chicago Computation Institute
> > jhammond at alcf.anl.gov / (630) 252-5381
> > http://www.linkedin.com/in/jeffhammond
> > https://wiki.alcf.anl.gov/parts/index.php/User:Jhammond
> -------------- next part --------------
> An HTML attachment was scrubbed...
> URL: <
> http://lists.mcs.anl.gov/pipermail/mpich2-dev/attachments/20121109/dbfe8fca/attachment-0001.html
> Message: 2
> Date: Fri, 9 Nov 2012 13:17:14 +0530
> From: Aman Madaan <madaan.amanmadaan at gmail.com>
> Subject: [mpich2-dev] No Gain For calculating maximum of an array
> Message-ID:
> CA+h7vmBLxppUR88uahVrbxNeTQKbnOy+HC5qajGF127Xn9BPUw at mail.gmail.com>
> Hello
> I am pretty new to MPI programming and i was doing some research on
> performance of dumped computers in our college.
> Although my cluster is giving the expected gain for many embarrassingly
> parallel problems,but the attached simple program for calculating maximum
> number in an array is unexpectedly slow.
> The file of numbers is first read at the root and the array is scattered to
> all the supporting nodes. Then MPI_REDUCE is used to get the global maximum
> The result of running the program are as follows :
> *Using 2 nodes : *
> axiom at node1:~/Programs/largest$ mpiexec -f f ./a.out numbers/num10000.txt
> 10000
> Maximum = 3999213
> wall clock time = 0.002819
> *Using single node : *
> axiom at node1:~/Programs/largest$ mpiexec  ./a.out numbers/num10000.txt
> 10000
> Maximum = 3999213
> wall clock time = 0.000168
> The situation remains same even after increasing the number of elements.
> I request your suggestions.
> Thanks a lot for your time.
> With regards
> Aman Madaan
> URL: <
> http://lists.mcs.anl.gov/pipermail/mpich2-dev/attachments/20121109/95f933a2/attachment-0001.html
> A non-text attachment was scrubbed...
> Type: text/x-csrc
> Desc: not available
> URL: <
> http://lists.mcs.anl.gov/pipermail/mpich2-dev/attachments/20121109/95f933a2/attachment-0001.c
> Message: 3
> Date: Fri, 9 Nov 2012 08:42:07 -0600
> To: mpich2-dev at mcs.anl.gov, madaan.amanmadaan at gmail.com
> Subject: Re: [mpich2-dev] No Gain For calculating maximum of an array
> Message-ID:
>         <CAGKz=u+2aQytQvDum1ENYqqwXwsHSStFu=
> HceeqRfV3e5xSQqA at mail.gmail.com>
> Please resend to mpich-discuss at mcs.anl.gov.
> Jeff
> On Fri, Nov 9, 2012 at 1:47 AM, Aman Madaan <madaan.amanmadaan at gmail.com>
> wrote:
> > Hello
> to
> maximum
> > Using 2 nodes :
> > 10000
> > Maximum = 3999213
> > Using single node :
> 10000
> > Maximum = 3999213
> > With regards
> > Aman Madaan
> Jeff Hammond
> End of mpich2-dev Digest, Vol 47, Issue 4
Aman Madaan
+91-9958725963
URL: <http://lists.mcs.anl.gov/pipermail/mpich2-dev/attachments/20121110/45adf312/attachment.html>
Type: text/x-csrc
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/mpich2-dev/attachments/20121110/45adf312/attachment.c>
More information about the mpich2-dev mailing list
