[mpich2-dev] Patch for mpich2/hydra downstream distributors
Pavan Balaji
balaji at mcs.anl.gov
Fri Mar 16 18:16:13 CDT 2012
Folks,
If you are an mpich2 downstream distributor, and are using Hydra from
1.4.1p1, you might want to consider applying this critical patch.
https://trac.mcs.anl.gov/projects/mpich2/changeset/9615
Without this, we were failing to clean up applications that call
MPI_ABORT correctly in some cases, causing applications to run forever
(or till their allocation runs out) even if a process terminated by
calling MPI_ABORT.
mpich2-1.5.x will have this patch. We haven't yet decided if we want to
release a new patch release in the 1.4.x series for this.
-- Pavan
PS: Yes, it is embarrassing. :-)
Pavan Balaji
http://www.mcs.anl.gov/~balaji
More information about the mpich2-dev
