[mpich2-dev] error in mpiexec
Dave Goodell goodell at mcs.anl.gov
Thu Feb 2 12:28:42 CST 2012
These are messages from Open MPI, not MPICH2.  Make sure that you PATH is setup correctly and that you uninstall your copy Open MPI in order to avoid conflicts.
-Dave
On Feb 2, 2012, at 12:25 PM CST, lagoun brahim wrote:
> hi there in
> i will use mpich2 (1.2;1.3;1.4 .p) configured with: ./configure --with-pm=gforker FC=gfortran F77=gfortran
> but when i execut mpiexec i have the same error :
> pdoc:/home/mpich2-1.4.1p1/examples # mpiexec -n 4 ./cpi
> [pdoc:04201] [NO-NAME] ORTE_ERROR_LOG: Not found in file runtime/orte_init_stage1.c at line 182
> It looks like orte_init failed for some reason; your parallel process is
> likely to abort.  There are many reasons that a parallel process can
> fail during orte_init; some of which are due to configuration or
> environment problems.  This failure appears to be an internal failure;
> here's some additional information (which may only be relevant to an
> Open MPI developer):
>   orte_rml_base_select failed
>   --> Returned value -13 instead of ORTE_SUCCESS
> [pdoc:04201] [NO-NAME] ORTE_ERROR_LOG: Not found in file runtime/orte_system_init.c at line 42
> [pdoc:04201] [NO-NAME] ORTE_ERROR_LOG: Not found in file runtime/orte_init.c at line 52
> Open RTE was unable to initialize properly.  The error occured while
> attempting to orte_init().  Returned value -13 instead of ORTE_SUCCESS.
> any suggestion or help
> i have a i7 990 with 12 cores my OS is opensuse 11.3 64 bits
> thank's in advance
More information about the mpich2-dev mailing list
