[mpich2-dev] MPIX vs. MPI etc.
Pavan Balaji
balaji at mcs.anl.gov
Sun Aug 19 22:42:03 CDT 2012
MPIX_ functions were always meant to be extensions beyond the MPI
standard. The fact that these functions might get into the standard in
MPI-3 does not change that fact. Apart from ARMCI-MPI, everything else
follows this rule correctly. ARMCI-MPI does not use MPIX_ names at all;
it is just in the wrong directory.
-- Pavan
On 08/19/2012 10:36 PM, Jeff Hammond wrote:
> I don't really care if we resolve this for all time tonight, I just
> think it's worth noting that the current situation is confusing if one
> tries to be logical about it.
> Jeff
> ---------- Forwarded message ----------
> From: Jeff Hammond <jhammond at alcf.anl.gov>
> Date: Sun, Aug 19, 2012 at 10:33 PM
> Subject: Re: [mpich-ibm] pamid code contribution - based on mpich2 1.5b2
> To: Pavan Balaji <balaji at mcs.anl.gov>
> Cc: William Gropp <wgropp at illinois.edu>, mpich-ibm at mcs.anl.gov
> I agree that a user will be annoyed if an MPIX_Ibarrier symbol exists
> in MPICH2-1.5's PAMID but it doesn't work, however...
> This refers to the MPIX implementations of MPI-3 that are not yet
> standardized, does it not? Is MPICH2-1.5 going to be an
> implementation of MPI-2.2 or MPI-3? If the former, what is the
> argument for not letting the PAMID implementation of MPICH2-1.5 catch
> on fire and burn down the machine room when users call MPIX_Ibarrier?
> They have no reasonable expectation that this should work. Only
> informed experts should be calling MPIX anyways, no?
> This further confirms that the MPIX situation is confusing. MPICH2
> has MPIX for MPI-3 that are portable except for BGQ, MPIX that have no
> meaning except on BGQ, and MPIX that aren't in the standard but work
> everywhere because they sit on top of MPI. It also strengthens my
> argument that there's no sense in trying to make MPIX user-friendly
> since these details are not something a novice can distinguish.
> The best solution is for IBM to implement all the MPIX functions in
> MPICH2-1.5, of course, starting with NBC and RMA :-)
> Jeff
> On Sun, Aug 19, 2012 at 10:26 PM, Pavan Balaji <balaji at mcs.anl.gov> wrote:
>> Agreed. I like Bill's suggestion better.
>> -- Pavan
>> On 08/19/2012 10:24 PM, William Gropp wrote:
>>> I have a different concern about this (not about the IBM patch but the
>>> underlying approach). I think it is a mistake to include unimplemented
>>> routines at all in the library. In particular, there is no easy way to
>>> write a configure test for this without running the code; the model that
>>> configure uses for checking for a the availability of a function is
>>> whether a program containing it can be linked. Applications should be
>>> encouraged to use standard tools for determining capabilities.
>>> Including non-functional stubs breaks this model, and does so
>>> unnecessarily.
>>> Bill
>>> William Gropp
>>> Director, Parallel Computing Institute
>>> Deputy Director for Research
>>> Institute for Advanced Computing Applications and Technologies
>>> Paul and Cynthia Saylor Professor of Computer Science
>>> University of Illinois Urbana-Champaign
>>> On Aug 20, 2012, at 9:43 AM, Pavan Balaji wrote:
>>>> 5. Patch #3: For the MPI-3 functionality that's not implemented, it
>>>> looks like you are just calling an Abort. I'd recommend adding a new
>>>> error code MPIX_ERR_NOT_IMPLEMENTED and return that instead. That
>>>> way, applications might be able to do something useful with those
>>>> functions.
>> Pavan Balaji
>> http://www.mcs.anl.gov/~balaji
>> mpich-ibm mailing list
>> mpich-ibm at lists.mcs.anl.gov
>> https://lists.mcs.anl.gov/mailman/listinfo/mpich-ibm
> Jeff Hammond
> Argonne Leadership Computing Facility
> University of Chicago Computation Institute
> jhammond at alcf.anl.gov / (630) 252-5381
> http://www.linkedin.com/in/jeffhammond
> https://wiki.alcf.anl.gov/parts/index.php/User:Jhammond
Pavan Balaji
More information about the mpich2-dev
