[mpich2-dev] CFLAGS=-fPIC not passed down to MPE ?
Lisandro Dalcin
dalcinl at gmail.com
Mon Aug 6 14:13:27 CDT 2012
On 6 August 2012 15:58, Anthony Chan <chan at mcs.anl.gov> wrote:
>> If you want a very short-term workaround, you can probably add "-fPIC"
>> to "$MPICPPFLAGS" in your environment.
> Passing -fPIC through MPICPPFLAGS to MPE configure is OK as a temporary
> workaround. I believe a correct fix is to pass -fPIC down as CFLAGS.
BTW, in the end the -fPIC bussines I'm caring about is related to
ticket $573 (http://trac.mcs.anl.gov/projects/mpich2/ticket/573). I
quote myself:
"For all this, I'm asking you for consideration to use -fPIC (if the
compiler support it, of course) when MPICH2's configure is asked for
--enable-sharedlibs."
For example, the Fedora RPM spec files do pass CFLAGS=-fPIC to
configure to get PIC code in libmpe.a, otherwise you cannot link-in
MPE in a shared library on x86_64.
Any thoughts about this? I understand the implications for the build
system, but do you at least agree that --enable-shared at the top
level should (by default) generate PIC code for all sources?
PS: I This is somewhat off-topic, feel free to ignore me.
Lisandro Dalcin
CIMEC (INTEC/CONICET-UNL)
Predio CONICET-Santa Fe
Colectora RN 168 Km 472, Paraje El Pozo
3000 Santa Fe, Argentina
Tel: +54-342-4511594 (ext 1011)
Tel/Fax: +54-342-4511169
More information about the mpich2-dev
