[mpich2-dev] mpiexec to call launcher for all names in machines file without hostname resolution (was -nolocal option)
John Marshall John.Marshall at ec.gc.ca
Fri Jul 8 23:46:16 CDT 2011
On 07/09/2011 12:30 AM, Pavan Balaji wrote:
> On 07/08/2011 11:29 PM, John Marshall wrote:
>> On 07/09/2011 12:18 AM, Pavan Balaji wrote:
>>> On 07/08/2011 11:11 PM, John Marshall wrote:
>>>> Perhaps there is some confusion here, but I don't see how my launcher
>>>> could be called since *is_local == 1.
>>> I'm confused on what exactly you need. Do you want Hydra to not fall back to fork when a local hostname is provided? Why?
>> Right. I want my launcher to be called for each entry in the machines list, even if that entry ends up on the local host. No
>> fall back to fork, ever.
>> Why? Because the entries in the machines file are _not_ necessarily hostnames. What they are is interpreted by the launcher
>> which effectively maps between the machines file entries and targets.
> I understand that they are not hostnames -- in such cases the host resolution will fail and you'll get this behavior anyway.
> Are you not getting this behavior?
My point is that, for what I am doing, any sort of host resolution is problematic because it conflates the namespace of the
machines file to be hostnames and not hostnames (i.e., when host resolution fails). I need for the machines file to be the
namespace of not hostnames.
As a convoluted example, suppose a machine had multiple hostnames: name0, name1, name2, and localhost. If I ran mpiexec from
that machine with the following machines file:
name0
name1
name2
localhost
as it is now and with your patch, hydra would fork, _not_ call my launcher. Instead, I want my launcher to be called each time,
no forking. Why? Because for my situation name0, name1, name2, and localhost are not hostnames but labels that my launcher
interprets.
John
More information about the mpich2-dev mailing list
