[mpich2-dev] mpiexec to call launcher for all names in machines file without hostname resolution (was -nolocal option)
John Marshall
John.Marshall at ec.gc.ca
Fri Jul 8 23:11:15 CDT 2011
On 07/08/2011 11:30 PM, Pavan Balaji wrote:
> John,
> Hydra will still pass the hostnames directly to the launcher; nothing gets changed by Hydra. The resolution of the hostname is
> used for its internal purposes.
> And a machinefile containing "localhost" will work fine.
I tried your patch and it does not work. When localhost is in the list of machine names, my launcher is not called. From what I
can tell:
* ht = gethostbyname("localhost") succeeds
* ht resolves to a local interface
* *is_local = 1 is executed
* goto fn_exit is executed
Perhaps there is some confusion here, but I don't see how my launcher could be called since *is_local == 1.
John
> -- Pavan
> On 07/08/2011 10:28 PM, John Marshall wrote:
>> On 07/08/2011 11:07 PM, Pavan Balaji wrote:
>>> Hi John,
>>> What's the benefit of allowing the user to disable this? If Hydra cannot resolve a hostname, it'll anyway consider it to be
>>> non-local. Note that your fix still doesn't solve the issue for the case I mentioned below.
>>> Btw, did you try the patch I provided?
>> I looked at your patch and for the case you mention it works. But it does not address my need because it still tests
>> gethostbyname(host). I don't want hydra to even bother checking that the machine names are valid hostnames. For example, with a
>> machines file (intentionally meant to thwart the patch) of:
>> localhost
>> your patch will resolve the name, but I need that name to be passed to the launcher-exec, no questions asked. The names in the
>> machines file that I want to use are simply labels, they are not hostnames. The possibility that these labels may match the
>> names of some hosts on the network is unintended and meant to be irrelevant.
>> Thanks,
>> John
>>> -- Pavan
>>> On 07/08/2011 09:56 PM, John Marshall wrote:
>>>> On 07/08/2011 10:31 PM, Pavan Balaji wrote:
>>>>> Hi John,
>>>>> Can you try this patch: http://pastebin.com/09iC9PdD
>>>>> There were two reasons for the local host check: (1) to figure out which cases we can avoid doing an ssh and instead just use
>>>>> a fork, and (2) workaround for cases where the default hostname of a node is not accessible over the network (in this case we
>>>>> try to find the "local hostname" in the host list passed by the user).
>>>>> While the first one is only a performance optimization, the second is a correctness issue. So we can't just disable the local
>>>>> test the way you did without breaking Hydra on some platforms. Instead, I have tried to handle this issue by not throwing a
>>>>> failure when a hostname doesn't resolve, and instead just assuming that it's not the local host.
>>>>> This is not a perfect solution as this will not work in cases where the second point above is true&& the user wants to use
>>>>> aliases instead of regular host names. But it might be OK for cases where one or both of the above two conditions is false.
>>>> Hi,
>>>> I suspect that this is a worthwhile change to make in general. However, I'd want to go even further by being able to expressly
>>>> tell hydra to not do any hostname resolution. That way there is no question about what to do.
>>>> I have something like the following (in the same sock.c file you mention):
>>>> 530,538d529
>>>> < /* JM - start */
>>>> < char *HYDRA_NO_LOCAL_ENV;
>>>> < HYDRA_NO_LOCAL_ENV = getenv("HYDRA_NO_LOCAL");
>>>> < if ((HYDRA_NO_LOCAL_ENV != NULL)&& (strcmp(HYDRA_NO_LOCAL_ENV, "1") == 0)) {
>>>> < *is_local = 0;
>>>> < goto fn_exit;
>>>> < /* JM - end */
>>>> with an 'export HYDRA_NO_LOCAL=1', all machine names are treated as not the local host, and thereby passed on to the launcher.
>>>> Would this actually mess anything up elsewhere in the code?
>>>> Given that the -nolocal is not what I thought, a name other than HYDRA_NO_LOCAL would be in order.
>>>> John
>>>>> -- Pavan
>>>>> On 07/08/2011 05:03 PM, John Marshall wrote:
>>>>>> On 07/08/2011 05:35 PM, Dave Goodell wrote:
>>>>>>> Was that the option to MPD's mpiexec that said "don't launch any processes on the local node, even though the local node is
>>>>>>> in the MPD ring"?
>>>>>>> If so, then hydra just doesn't need such an option. Simply don't include the local/head node in the machinefile and hydra
>>>>>>> won't launch any processes there.
>>>>>>> Or are you trying to obtain the effect of setting the "MPICH_NOLOCAL" environment variable to "1"? That says don't use
>>>>>>> shared memory to communicate between processes on the same node.
>>>>>> The mpd option is closer to what I am looking for but still not it because I do want to be able to start up a process on the
>>>>>> local node also.
>>>>>> For example, with a machines file:
>>>>>> 00
>>>>>> 01
>>>>>> 02
>>>>>> I want mpiexec to blindly call my launcher with the machine names of 00, 01, and 02 without trying to resolve the names (of
>>>>>> course, 00, 01, 02 are not hostnames). So, in effect, my machine names are really just labels which the launcher will
>>>>>> interpret.
>>>>>> The problem is, mpiexec wants to resolve the entries in the machines file, expecting that they are hostnames.
>>>>>> My change simply forces an is_local = 0 for all names. Is there an alternative?
>>>>>> Thanks,
>>>>>> John
>>>>>>> -Dave
>>>>>>> On Jul 8, 2011, at 4:29 PM CDT, John Marshall wrote:
>>>>>>>> Hi,
>>>>>>>> From what I can tell, there is no longer a nolocal option. For what I am doing, I currently need this kind of
>>>>>>>> functionality since the entries in my "machines" list are not actual machine names but labels. I have made a quick change
>>>>>>>> to src/pm/hydra/utils/sock/sock.c so that if an env var is set, all machines are treated as non-local (*is_local = 0).
>>>>>>>> I know I'm late to the party on this, but can someone explain why the -nolocal option was removed. Or, maybe I have missed
>>>>>>>> something to get this functionality, i.e., to pass the machine name/label to the launcher as is without any
>>>>>>>> complaints/errors and let the launcher interpret.
>>>>>>>> Thanks,
>>>>>>>> John
URL: <http://lists.mcs.anl.gov/pipermail/mpich2-dev/attachments/20110709/9105a45a/attachment.htm>
More information about the mpich2-dev
