[mpich2-dev] mpiexec to call launcher for all names in machines file without hostname resolution (was -nolocal option)
Pavan Balaji
balaji at mcs.anl.gov
Fri Jul 8 22:07:39 CDT 2011
Hi John,
What's the benefit of allowing the user to disable this? If Hydra cannot
resolve a hostname, it'll anyway consider it to be non-local. Note that
your fix still doesn't solve the issue for the case I mentioned below.
Btw, did you try the patch I provided?
-- Pavan
On 07/08/2011 09:56 PM, John Marshall wrote:
> On 07/08/2011 10:31 PM, Pavan Balaji wrote:
>> Hi John,
>> Can you try this patch: http://pastebin.com/09iC9PdD
>> There were two reasons for the local host check: (1) to figure out which cases we can avoid doing an ssh and instead just use
>> a fork, and (2) workaround for cases where the default hostname of a node is not accessible over the network (in this case we
>> try to find the "local hostname" in the host list passed by the user).
>> While the first one is only a performance optimization, the second is a correctness issue. So we can't just disable the local
>> test the way you did without breaking Hydra on some platforms. Instead, I have tried to handle this issue by not throwing a
>> failure when a hostname doesn't resolve, and instead just assuming that it's not the local host.
>> This is not a perfect solution as this will not work in cases where the second point above is true&& the user wants to use
>> aliases instead of regular host names. But it might be OK for cases where one or both of the above two conditions is false.
> Hi,
> I suspect that this is a worthwhile change to make in general. However, I'd want to go even further by being able to expressly
> tell hydra to not do any hostname resolution. That way there is no question about what to do.
> I have something like the following (in the same sock.c file you mention):
> 530,538d529
> < /* JM - start */
> < char *HYDRA_NO_LOCAL_ENV;
> < HYDRA_NO_LOCAL_ENV = getenv("HYDRA_NO_LOCAL");
> < if ((HYDRA_NO_LOCAL_ENV != NULL)&& (strcmp(HYDRA_NO_LOCAL_ENV, "1") == 0)) {
> < *is_local = 0;
> < goto fn_exit;
> < /* JM - end */
> with an 'export HYDRA_NO_LOCAL=1', all machine names are treated as not the local host, and thereby passed on to the launcher.
> Would this actually mess anything up elsewhere in the code?
> Given that the -nolocal is not what I thought, a name other than HYDRA_NO_LOCAL would be in order.
> John
>> -- Pavan
>> On 07/08/2011 05:03 PM, John Marshall wrote:
>>> On 07/08/2011 05:35 PM, Dave Goodell wrote:
>>>> Was that the option to MPD's mpiexec that said "don't launch any processes on the local node, even though the local node is
>>>> in the MPD ring"?
>>>> If so, then hydra just doesn't need such an option. Simply don't include the local/head node in the machinefile and hydra
>>>> won't launch any processes there.
>>>> Or are you trying to obtain the effect of setting the "MPICH_NOLOCAL" environment variable to "1"? That says don't use
>>>> shared memory to communicate between processes on the same node.
>>> The mpd option is closer to what I am looking for but still not it because I do want to be able to start up a process on the
>>> local node also.
>>> For example, with a machines file:
>>> 00
>>> 01
>>> 02
>>> I want mpiexec to blindly call my launcher with the machine names of 00, 01, and 02 without trying to resolve the names (of
>>> course, 00, 01, 02 are not hostnames). So, in effect, my machine names are really just labels which the launcher will interpret.
>>> The problem is, mpiexec wants to resolve the entries in the machines file, expecting that they are hostnames.
>>> My change simply forces an is_local = 0 for all names. Is there an alternative?
>>> Thanks,
>>> John
>>>> -Dave
>>>> On Jul 8, 2011, at 4:29 PM CDT, John Marshall wrote:
>>>>> Hi,
>>>>> From what I can tell, there is no longer a nolocal option. For what I am doing, I currently need this kind of
>>>>> functionality since the entries in my "machines" list are not actual machine names but labels. I have made a quick change
>>>>> to src/pm/hydra/utils/sock/sock.c so that if an env var is set, all machines are treated as non-local (*is_local = 0).
>>>>> I know I'm late to the party on this, but can someone explain why the -nolocal option was removed. Or, maybe I have missed
>>>>> something to get this functionality, i.e., to pass the machine name/label to the launcher as is without any
>>>>> complaints/errors and let the launcher interpret.
>>>>> Thanks,
>>>>> John
Pavan Balaji
http://www.mcs.anl.gov/~balaji
More information about the mpich2-dev
