[mpich2-dev] Adding an ADIO layer to MPICH
John Bent johnbent at lanl.gov
Sun Jul 3 11:56:22 CDT 2011
Excerpts from John Esmet's message of Sat Jun 25 09:57:34 -0600 2011:
> All,
> I'm looking to implement an ADIO layer for MPICH. Is there an outline or a
> guide for what needs to be done to patch MPICH to fully build and recognize
> my ADIO layer? Places to put code, Makefile, config modifications, that sort
> of thing.
PLFS has done this in the past although currently we're more focused on openmpi so this patch hasn't been maintained in a long time.  But the attached patch I believe does go through all the mpich Makefile's and .am files and everything that needs to be patched.  Then you need to go in and add a new directory in romio/adio will your files.  However, for prototyping something for research purposes, my recommendation would be to just go into romio/adio/ad_pvfs and replace all the code in there with your code.  That way you don't need to mess with the complicated build mechanisms.  PLFS patch attached (also available through sourceforge.net).
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/mpich2-dev/attachments/20110703/e676a446/attachment.obj>
More information about the mpich2-dev mailing list
