[mpich2-dev] problem with parallel of wien2k
Dave Goodell
goodell at mcs.anl.gov
Tue Jan 11 12:29:47 CST 2011
It looks like you've linked against MPICH2 but used MPICH1 headers. Don't mix and match MPI implementations, and make sure to use the compiler wrappers provided by MPICH2 (mpicc, mpif77, etc).
-Dave
On Jan 11, 2011, at 12:16 PM CST, lagoun brahim wrote:
> I compile a WIEN2k code with mpich2 with: ./configure --with-pm = hydra (gforker)
> but when I run the parallel version I had the following error message:
> LAPW0 END
> Fatal error in MPI_Comm_size: Invalid communicator, error stack:
> MPI_Comm_size(111): MPI_Comm_size(comm=0x5b, size=0x8d9d6c) failed
> MPI_Comm_size(69).: Invalid communicator
> cat: No match.
> i dont now where is the problem
> any suggestion
> and thanks in advance
More information about the mpich2-dev
