[mpich2-dev] regarding checkpointing using BLCR in MPICH2
Hao Yang
hao.yang0614 at gmail.com
Mon Dec 12 14:28:45 CST 2011
Hi, all:
I found checkpoint failure when I use MPICH with BLCR in my machine.
We tried inserting MPI_Iprobe in the program, but the second checkpoint
still failed.
Alternatively, we try to set MPI_ASYNC_PROGRESS to enable a MPI progress
thread which may help processes execute checkpoint algorithm. We first use
--enable-async-progress when we build MPICH and then run "mpiexec -env
MPICH_ASYNC_PROGRESS 1 -n 5 ./mpitest". But we met an error "Assertion
failed in file async.c at line 52: !mpi_errno. internal ABORT - process 0".
Does anyone know how to fix this? Thank you.
URL: <http://lists.mcs.anl.gov/pipermail/mpich2-dev/attachments/20111212/b43b94ef/attachment.htm>
More information about the mpich2-dev
