[mpich2-dev] [ewg] Problems with mvapich2-1.5.1 - shared library is missing hwloc_* functions.
Dhabaleswar Panda panda at cse.ohio-state.edu
Mon Sep 13 20:39:51 CDT 2010
Dave and Mike - Jonathan posted a follow-up reply on this already. The
latest 1.5.1 version uploaded to OFED during the weekend has solved this
problem. The OFED daily build has already this fix. This latest MVAPICH2
version (1.5.1) is planned to be released tomorrow.
Mike - Please feel free to post your MVAPICH2 related questions to the
MVAPICH mailing list.
DK
On Fri, 10 Sep 2010, Dave Goodell wrote:
> Hi Mike,
> Stock MPICH2 does not use hwloc directly inside the MPI library.  It is only used by the hydra process manager.  MVAPICH2 appears to be using hwloc directly inside the library, so you'll need to ask the OSU folks for a fix.
> They can be contacted at mvapich-discuss at cse.ohio-state.edu.
> http://mail.cse.ohio-state.edu/mailman/listinfo/mvapich-discuss
> -Dave
> On Sep 10, 2010, at 1:42 PM CDT, Mike Heinz wrote:
> > Hello all,
> > I'm trying to build mvapich2-1.5.1 on an RHEL 5 update 3 system. It builds from the SRPM just fine, but when I try to compile test programs, they don't link. It appears that a set of routines, hwloc_* are missing from the shared library.
> > [root at homer bandwidth]# /usr/mpi/gcc/mvapich2-1.5.1/bin/mpicc bw.c
> > /usr/mpi/gcc/mvapich2-1.5.1/lib/libmpich.so: undefined reference to `hwloc_get_obj_by_depth'
> > /usr/mpi/gcc/mvapich2-1.5.1/lib/libmpich.so: undefined reference to `hwloc_topology_get_depth'
> > /usr/mpi/gcc/mvapich2-1.5.1/lib/libmpich.so: undefined reference to `hwloc_set_cpubind'
> > /usr/mpi/gcc/mvapich2-1.5.1/lib/libmpich.so: undefined reference to `hwloc_topology_init'
> > /usr/mpi/gcc/mvapich2-1.5.1/lib/libmpich.so: undefined reference to `hwloc_cpuset_cpu'
> > /usr/mpi/gcc/mvapich2-1.5.1/lib/libmpich.so: undefined reference to `hwloc_get_depth_type'
> > /usr/mpi/gcc/mvapich2-1.5.1/lib/libmpich.so: undefined reference to `hwloc_get_type_depth'
> > /usr/mpi/gcc/mvapich2-1.5.1/lib/libmpich.so: undefined reference to `hwloc_get_nbobjs_by_depth'
> > /usr/mpi/gcc/mvapich2-1.5.1/lib/libmpich.so: undefined reference to `hwloc_compare_types'
> > /usr/mpi/gcc/mvapich2-1.5.1/lib/libmpich.so: undefined reference to `hwloc_topology_destroy'
> > /usr/mpi/gcc/mvapich2-1.5.1/lib/libmpich.so: undefined reference to `hwloc_topology_load'
> > /usr/mpi/gcc/mvapich2-1.5.1/lib/libmpich.so: undefined reference to `hwloc_cpuset_alloc'
> > collect2: ld returned 1 exit status
> > compared with:
> > [root at homer bandwidth]# /usr/mpi/gcc/mvapich2-1.5.1/bin/mpicc  bw.c /usr/mpi/gcc/mvapich2-1.5.1/lib/libmpich.a
> > [root at homer lib]# nm libmpich.so | grep hwloc_compare_types
> >                 U hwloc_compare_types
> > [root at homer lib]# nm libmpich.a | grep hwloc_compare_types
> > 0000000000000020 T hwloc_compare_types
> > I'm building the binary RPM as follows:
> > [root at homer SRPMS]# rpmbuild --rebuild
> >              --define '_topdir /home/mhein^Mnz/work/OFED_SOURCE/buildtemp/OFEDRPMS'
> >              --buildroot '/home/mheinz^Mz/work/OFED_SOURCE/buildtemp/build'
> >              --define 'build_root /home/mh^Mheinz/work/OFED_SOURCE/buildtemp/build'
> >              --target x86_64 --define ^M '_name mvapich2_gcc'
> >              --define 'compiler gcc'    --define 'impl of^Mfa'
> >              --define 'open_ib_home /usr'     --define '_usr /usr'
> >              --define 'comp_env CC=gcc CXX=g++ F77=gfortran F90=gfortran'
> >              --define 'auto_req 0'
> >              --define 'mpi_selector /usr/bin/mpi-sele^Mector'
> >              --define '_prefix /usr/mpi/gcc/mvapich2-1.5.1'
> >              --define 'shaared_libs 1'
> >              --define 'romio 1'
> >              --define 'rdma --with-rdma=gen2'
> >              --define 'ib_include --with-ib-include=/usr/include'
> >              --define 'ib_libpath --with-ib-libpath=/usr/lib64'
> >              --define 'configure_options  --with-psm==no'
> >              mvapich2-*.src.rpm
> > Can someone tell me what I'm doing wrong?
> ewg mailing list
> ewg at lists.openfabrics.org
> http://lists.openfabrics.org/cgi-bin/mailman/listinfo/ewg
More information about the mpich2-dev mailing list
