[mpich2-dev] mpe2 build patches.
    Justin Bronder
    jsbronder at gentoo.org
    Mon Sep 13 13:56:37 CDT 2010
Gentoo bug #335590[1] pointed out that the trace examples in slog2sdk were
building without supporting user-defined LDFLAGS.  The two attached patches
fix this as well as removing installation of the libraries from the compile
phase of the build.
Hopefully I'm sending these patches to the correct list, if not, please
accept my apologies.
1. http://bugs.gentoo.org/show_bug.cgi?id=335590
From 5bc91497bd4b3d2e4e962ffb2d5b9b471c4183c2 Mon Sep 17 00:00:00 2001
Date: Mon, 13 Sep 2010 14:18:51 -0400
Subject: [PATCH 1/2] slog2sdk/trace_rlog makefile fixes
- Respect user-defined LDFLAGS when linking PGM_PRINT and PGM_CHECK.
- Do not install libraries during the compile phase.
 src/slog2sdk/trace_rlog/src/Makefile.in |   19 ++++++++-----------
 1 files changed, 8 insertions(+), 11 deletions(-)
diff --git a/src/slog2sdk/trace_rlog/src/Makefile.in b/src/slog2sdk/trace_rlog/src/Makefile.in
index 9b289b8..2d772e0 100644
--- a/src/slog2sdk/trace_rlog/src/Makefile.in
+++ b/src/slog2sdk/trace_rlog/src/Makefile.in
@@ -48,7 +48,8 @@ RM               = @RM@
 JNI_INC          = @JNI_INC@
 CFLAGS           = -I.. $(JNI_INC) -I$(TRACE_INCDIR) @COPTS@
-LDFLAGS          = -module -no-undefined -avoid-version @LDFLAGS@
+LDFLAGS          = @LDFLAGS@
+LIBLDFLAGS       = -module -no-undefined -avoid-version @LDFLAGS@
 # memory leak checker
 MEMLIBS          = @DEBUG_LIBS@
@@ -66,33 +67,29 @@ ALL: $(libbuild_dir)/$(LIB_TRACE) $(binbuild_dir)/$(PGM_PRINT) $(binbuild_dir)/$
 $(libbuild_dir)/$(LIB_TRACE): $(LOBJ)
 	if [ "$(EXPORT_SYMBOLS)" = "yes" ] ; then \
-	    $(LIBTOOL) --mode=link $(CC) -o $(LIB_TRACE) $(LOBJ) $(LDFLAGS) \
+	    $(LIBTOOL) --mode=link $(CC) -o $(LIB_TRACE) $(LOBJ) $(LIBLDFLAGS) \
 	               -export-symbols $(srcdir)/JavaTraceInput.sym \
 	               -rpath $(libbuild_dir) ; \
 	else \
 	fi
-	$(LIBTOOL) --mode=install $(INSTALL) $(LIB_TRACE) $(libbuild_dir)
-	$(LIBTOOL) --finish $(libbuild_dir)
 INSTALL_LIBSO: $(LOBJ)
 	               -rpath $(LIBDIR) ; \
 	else \
 	fi
-	$(LIBTOOL) --mode=install $(INSTALL) $(LIB_TRACE) $(DESTDIR)$(LIBDIR)
-	$(LIBTOOL) --finish $(LIBDIR)
 $(binbuild_dir)/$(PGM_PRINT): $(OBJ4T)
-	$(CC) @COPTS@ -o $@ $(OBJ4T) $(MEMLIBS)
+	$(CC) @COPTS@ $(LDFLAGS) -o $@ $(OBJ4T) $(MEMLIBS)
 $(binbuild_dir)/$(PGM_CHECK): $(OBJ4E)
-	$(CC) @COPTS@ -o $@ $(OBJ4E) $(MEMLIBS)
+	$(CC) @COPTS@ $(LDFLAGS) -o $@ $(OBJ4E) $(MEMLIBS)
 clean:
 	@-$(RM) *. at OBJEXT@ *.lo *.la
1.7.1
From b23d8d40cf62d03cad7ce777565069368e040a96 Mon Sep 17 00:00:00 2001
Date: Mon, 13 Sep 2010 14:22:10 -0400
Subject: [PATCH 2/2] slog2sdk/trace_sample makefile fixes
 src/slog2sdk/trace_sample/src/Makefile.in |   19 ++++++++-----------
diff --git a/src/slog2sdk/trace_sample/src/Makefile.in b/src/slog2sdk/trace_sample/src/Makefile.in
index f716fff..8d3641a 100644
--- a/src/slog2sdk/trace_sample/src/Makefile.in
+++ b/src/slog2sdk/trace_sample/src/Makefile.in
 JNI_INC          = @JNI_INC@
 	else \
 	fi
 	else \
 	fi
 clean:
1.7.1
Justin Bronder
Name: not available
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/mpich2-dev/attachments/20100913/3655df42/attachment.pgp>
More information about the mpich2-dev
