[mpich2-dev] hydra: redirecting stdout/err
Pavan Balaji
balaji at mcs.anl.gov
Fri Oct 29 16:34:50 CDT 2010
Ah, I see. Unfortunately, there's no easy way to do this right now. What
you did below should work, but it might be better to add such a feature
in Hydra itself.
Can you create a ticket for this?
https://trac.mcs.anl.gov/projects/mpich2/newticket
-- Pavan
On 10/29/2010 01:58 PM, Peter Johnson wrote:
> Hi Pavan, thanks for replying.
> I'm actually looking for a way to separately redirect the output of each
> process forked by mpiexec. I found the solution, though:
> $ mpiexec sh -c '/path/to/binary>$PMI_RANK.out 2>$PMI_rank.err'
> pete
> On Fri, Oct 29, 2010 at 12:59:35AM -0500, Pavan Balaji wrote:
>> Are you trying to send stdout to a separate file from stderr? You
>> can do that using:
>> % mpiexec -f hosts -n 4 ./foo> out 2> err
>> -- Pavan
>> On 10/28/2010 04:10 PM, Peter Johnson wrote:
>>> Hi --
>>> I'd find it really useful to be able to separately redirect stdout and stderr
>>> for each process spawned by Hydra. The wiki claims this is possible [1], and
>>> it appears support therefor was been committed to a developer branch a couple
>>> years ago [2], but the code doesn't seem to have made it to the 1.3 trunk.
>>> Any ideas why it's missing? Google couldn't find for me any discussion on the
>>> topic. Thanks.
>>> pete
>>> [1] http://wiki.mcs.anl.gov/mpich2/index.php/Hydra_Output_Redirection
>>> [2] http://trac.mcs.anl.gov/projects/mpich2/changeset/4785
>> Pavan Balaji
>> http://www.mcs.anl.gov/~balaji
Pavan Balaji
More information about the mpich2-dev
