[mpich2-dev] hydra: redirecting stdout/err
Peter Johnson pete at cs.dartmouth.edu
Mon Nov 1 12:42:34 CDT 2010
Done:
    https://trac.mcs.anl.gov/projects/mpich2/ticket/1131
pete
On Fri, Oct 29, 2010 at 04:34:50PM -0500, Pavan Balaji wrote:
> Ah, I see. Unfortunately, there's no easy way to do this right now.
> What you did below should work, but it might be better to add such a
> feature in Hydra itself.
> Can you create a ticket for this?
> https://trac.mcs.anl.gov/projects/mpich2/newticket
>  -- Pavan
> On 10/29/2010 01:58 PM, Peter Johnson wrote:
> >Hi Pavan, thanks for replying.
> >I'm actually looking for a way to separately redirect the output of each
> >process forked by mpiexec.  I found the solution, though:
> >     $ mpiexec sh -c '/path/to/binary>$PMI_RANK.out 2>$PMI_rank.err'
> >pete
> >On Fri, Oct 29, 2010 at 12:59:35AM -0500, Pavan Balaji wrote:
> >>Are you trying to send stdout to a separate file from stderr? You
> >>can do that using:
> >>% mpiexec -f hosts -n 4 ./foo>  out 2>  err
> >>  -- Pavan
> >>On 10/28/2010 04:10 PM, Peter Johnson wrote:
> >>>Hi --
> >>>I'd find it really useful to be able to separately redirect stdout and stderr
> >>>for each process spawned by Hydra.  The wiki claims this is possible [1], and
> >>>it appears support therefor was been committed to a developer branch a couple
> >>>years ago [2], but the code doesn't seem to have made it to the 1.3 trunk.
> >>>Any ideas why it's missing?  Google couldn't find for me any discussion on the
> >>>topic.  Thanks.
> >>>pete
> >>>[1] http://wiki.mcs.anl.gov/mpich2/index.php/Hydra_Output_Redirection
> >>>[2] http://trac.mcs.anl.gov/projects/mpich2/changeset/4785
> >>Pavan Balaji
> >>http://www.mcs.anl.gov/~balaji
> Pavan Balaji
More information about the mpich2-dev mailing list
