[mpich2-dev] Parent terminates when the spawned child terminates
Suraj Prabhakaran
suraj.prabhakaran at gmail.com
Wed Dec 15 16:11:55 CST 2010
Thank you guys for all the reply. Thanks Pavan for hinting at the auto
cleanup option. This does what I wanted it to do. Just adding to the
discussion, I agree with your comments on the portable program's
assumption part. The standard states that one program's error may affect
the other only if they somehow belong in an intra or inter communicator.
And in my case, the parent spawns the child and disconnects the
communicator. The child also as soon as init, gets the parent and
disconnects from the parent. The sample code is given below.
Parent:
int main (int argc, char *argv[])
MPI_Init(&argc, &argv);
MPI_Errhandler_set(MPI_COMM_WORLD, MPI_ERRORS_RETURN);
MPI_Comm child_comm;
MPI_Comm_spawn("./child", MPI_ARGV_NULL, 1, MPI_INFO_NULL, 0,
MPI_COMM_SELF, &child_comm, MPI_ERRCODES_IGNORE);
MPI_Errhandler_set(child_comm, MPI_ERRORS_RETURN);
printf("spawned a child\n");
MPI_Comm_disconnect(&child_comm);
printf("Disconnected from the child\n");
sleep(5000);
MPI_Finalize();
return 0;
Child:
MPI_Comm parent, parent1;
MPI_Comm_get_parent(&parent);
MPI_Comm_disconnect(&parent);
if(parent == MPI_COMM_NULL)
printf("Child: Disconnected from the parent, Exiting\n\n");
MPI_Comm_get_parent(&parent1);
if(parent1 != MPI_COMM_NULL)
printf("Child: yes, i got my parent again\n");
exit(1);
MPI_Finalize();
return 0;
If you see here, the child's first message will be displayed while the
second printf will not be displayed! Which shows that it cant get the
parent anymore. And when a exit() happens abruptly, it shouldn't affect
the parent rite (since they now dont have a common communicator, and
without any auto clean option) ?
Please correct me if I am wrong.
Suraj
On 12/15/2010 05:47 PM, Pavan Balaji wrote:
> On 12/15/2010 10:42 AM, Lisandro Dalcin wrote:
>> On 15 December 2010 13:34, Pavan Balaji<balaji at mcs.anl.gov> wrote:
>>> The standard leaves it pretty open, saying that an error in one
>>> application
>>> *may* affect the other. What exactly is done depends on the MPI
>>> implementation.
>> Of course, but I understand that a portable program should assume that
>> errors in one app *do* affect the other... and then be very careful
>> with usages of exit(), abort() and friends.
> Agreed. At least till we get to MPI-3 :-).
> -- Pavan
URL: <http://lists.mcs.anl.gov/pipermail/mpich2-dev/attachments/20101215/eabfa605/attachment.htm>
More information about the mpich2-dev
