[mpich2-dev] Fw: Another romio performance question
Bob Cernohous
bobc at us.ibm.com
Tue Sep 8 12:50:43 CDT 2009
Where can we point our customers for documentation? I found the old ROMIO
user's guide on
http://www.mcs.anl.gov/research/projects/romio/
which has some discussion of hints. Is there anything else available?
Bob Cernohous: (T/L 553) 507-253-6093
BobC at us.ibm.com
IBM Rochester, Building 030-2(C335), Department 61L
3605 Hwy 52 North, Rochester, MN 55901-7829
> Chaos reigns within.
> Reflect, repent, and reboot.
> Order shall return.
----- Forwarded by Bob Cernohous/Rochester/IBM on 09/08/2009 12:48 PM
08/21/2009 12:09 PM
To
mpich2-dev at mcs.anl.gov
cc
Subject
Re: [mpich2-dev] Another romio performance question
mpich2-dev-bounces at mcs.anl.gov wrote on 08/21/2009 11:38:17 AM:
> When the workload is as you describe, ROMIO normally looks at the
> accesses and if there is any overlap, it decides it would be better
> served with independent access (in ad_write_coll.c there's a check for
> interleaved accesses). Contiguous data like your customer's falls
> under the non-interleaved category.
> However, on BlueGene, the romio_cb_read and romio_cb_write hints are
> set to 'enable' instead of 'automatic'. This is usually the right
> thing, since aggregation works great on bluegene for workloads that
> are non-overlapping, but also non-contiguous.
Ok, so I tried hinting romio_cb_read/write to automatic and it doesn't do
the aggregation and performs much better. I like that even better than
hinting cb_buffer_size.
I think we're ok. Like you said, we might want to look at our defaults
and selection logic eventually, but I think I'm happy with my answer for
now.
Thanks
BobC at us.ibm.com
> Order shall return.
URL: <http://lists.mcs.anl.gov/pipermail/mpich2-dev/attachments/20090908/f3ece2a6/attachment.htm>
More information about the mpich2-dev
