[mpich2-dev] build issues with MPE on Windows(32) and MinGW
Lisandro Dalcin dalcinl at gmail.com
Mon Nov 2 15:20:50 CST 2009
On Mon, Nov 2, 2009 at 5:35 PM,  <jayesh at mcs.anl.gov> wrote:
> Hi,
Sorry for taking so long to get back... I have little Windows
experience, and your mail REALLY confused me. I had to start from
scratch and uninstall DeinoMPI, MPICH2 and MS HPC Cluster Pack from my
Windows system to make sure I was not being bitten by the infamous
"DLL Hell" :-) ... In the process, I've discovered that for upgrading
MPICH2, fist I have to uninstall the previous version :-( (BTW, is
this right?)... But I think I was able to get things cleaned-up and
then re-installed latest MPICH2-1.2 using the MSI installer.
>  We currently don't provide a mingw compatible library for MPE on windows.
What that means? This is the part that confused me...
I've just built a Python extension module linked against MPE...
because of the way my code works and Windows limitations (no
equivalent to dlopen() with RTLD_GLOBAL, AFAIK), I cannot log MPI
calls, but the logging of user-defined event and states is definitely
working (to be honest, just a sequential try, no mpiexec involved).
So I think you are wrong... MPE (at least some parts) do work with
MinGW on Windows(32) ... Why did you said that this is not supported??
> Why are you using the MPE header files provided with MPICH2 on windows with mingw?
Because I want my code (i.e, mpi4py) to work with MinGW. No more, no
less... And part of MPE (I mean, at least the logging of user-defined
states and events) DO WORK with MinGW after using the fix commented in
my previous mail (I mean, #include stdint.h and inttypes.h)
> (PS: The CLOG types are defined using pre-defined windows types. There is no need to include <stdint.h> or <inttypes.h> on windows.)
But if you want to use MinGW, it seems you have to include these two
headers to make GCC "understand" these pre-defined windows types.
PS: Am I being clear enough?
> Regards,
> Jayesh
> From: "Lisandro Dalcin" <dalcinl at gmail.com>
> To: mpich2-dev at mcs.anl.gov
> Sent: Monday, November 2, 2009 1:02:46 PM GMT -06:00 US/Canada Central
> Subject: [mpich2-dev] build issues with MPE on Windows(32) and MinGW
> Anthony, this is unrelated to our previous discussions about -fPIC, so
> I'm reporting the issue here. I hope it is the right place. If not,
> let me know (perhaps mpich-discuss ??).
> This diff at Google Code will be clear enough, I think:
> http://code.google.com/p/mpi4py/source/diff?spec=svn522&r=522&format=side&path=/trunk/src/MPE/mpe-log.c
> Without these two headers included, my Python ext module fails bad to
> build with MinGW. Interestingly, "clog_inttypes.h" has these two
> includes commented out on Windows (using the binary installer here).
> So perhaps protecting the inclusion of these two headers as shown in
> the link above will do the trick? To put it clear, I'm talking about
> using this:
>   #if defined(_WIN32) && defined(__GNUC__)
>     #include <stdint.h>
>     #include <inttypes.h>
>   #endif
> Lisandro Dalcín
> Centro Internacional de Métodos Computacionales en Ingeniería (CIMEC)
> Instituto de Desarrollo Tecnológico para la Industria Química (INTEC)
> Consejo Nacional de Investigaciones Científicas y Técnicas (CONICET)
> PTLC - Güemes 3450, (3000) Santa Fe, Argentina
> Tel/Fax: +54-(0)342-451.1594
Lisandro Dalcín
More information about the mpich2-dev mailing list
