[mpich2-dev] bugs in test/mpi/configure.in
David Gingold
david.gingold at sicortex.com
Tue Feb 17 09:38:08 CST 2009
MPICH2 folks --
I spent some time last week puzzling over why, when configuring the
MPICH2 tests, the configure script was doing this:
checking that we can build MPI programs with Fortran 90... no
when in fact mpif90 was working fine. The cause appears to be a bug
in test/mpi/configure.in.
The patch below (to the 1.1a1 code) has three changes. I think it's
the middle change that fixed my problem, but the other two seemed, on
their face, to be bugs as well.
Please review this with skepticism. I am no autoconf wizzard!
Note that I'm attempting to get the tests to run standalone against
the installed MPI library on our system. I am configuring them, for
example, this way:
$ CC=gcc CXX=g++ F77=pathf95 F90=pathf95 ./configure --disable-spawn
--disable-romio --enable-f77 --enable-f90 --enable-cxx --enable-
threads=serialized --enable-checkerrors --with-mpi=/usr
-dg
Index: configure.in
--- configure.in (revision 70089)
+++ configure.in (working copy)
@@ -182,6 +182,16 @@
enable_f77=no
fi
fi
+if test "$enable_f90" = yes ; then
+ AC_PROG_F90
+ if test -z "$BASEF90" ; then
+ BASEF90="$F90"
+ fi
+ # If there is no working F90, then set enable_f90 to no
+ if test -z "$F90" ; then
+ enable_f90=no
+ fi
+fi
if test "$enable_cxx" = yes ; then
AC_PROG_CXX
if test -z "$BASECXX" ; then
@@ -227,6 +237,11 @@
else
F77=$MPIF77
fi
+ if test -z "$MPIF90" ; then
+ F90=$with_mpi/bin/mpif90
+ else
+ F90=$MPIF90
+ fi
if test -z "$MPICXX" ; then
CXX=$with_mpi/bin/mpicxx
else
@@ -659,7 +674,9 @@
elif test -z "$BASEF90" ; then
BASEF90=$F90
fi
- F90=$saveF90
+ if test -n "$BASEF90" ; then
+ F90=$saveF90
+ fi
fi
More information about the mpich2-dev
