[mpich2-dev] mpich 1.1 beta: details of MPI_Win_fence semantics
Rajeev Thakur thakur at mcs.anl.gov
Tue Apr 14 10:40:11 CDT 2009
Doug,
     A call to fence both completes the previous epoch (if there was one)
and starts the next epoch, as described on pg 338 of MPI 2.1. In other
words, the sequence fence-put-fence-put-fence is allowed. MPICH2 handles
this case. That is why there are the asserts MPI_MODE_NOPRECEDE and
MPI_MODE_NOSUCCEED for the user to indicate otherwise. Unless the user
passes these asserts or it is the very first fence, the implementation
should assume that a given fence can be preceded by puts/gets and followed
by puts/gets.
Rajeev
> -----Original Message-----
> From: mpich2-dev-bounces at mcs.anl.gov
> [mailto:mpich2-dev-bounces at mcs.anl.gov] On Behalf Of Douglas Miller
> Sent: Tuesday, April 14, 2009 9:53 AM
> To: mpich2-dev at mcs.anl.gov
> Subject: [mpich2-dev] mpich 1.1 beta: details of
> Some new tests in mpich 1.1 beta use MPI_Win_fence in an
> unexpected (to me)
> fashion. They do the following:
> [fence - NOPRECEDE]
> [RMA operations]
> [fence - 0]
> [RMA operations]
> [fence - 0]
> [RMA operations]
> [fence - NOSUCCEED]
> I was assuming that MPI_Win_fence was *either* starting or
> completing an
> epoch (i.e. there were always matched-pairs of fence calls),
> not both. But
> this usage implies that there is an expectation that a single
> call to fence
> can *both* end an epoch and start a new epoch. The
> specification is vague
> at best.
> The problem with the above usage is that the middle calls to
> fence create a
> situation where the implementation cannot be certain whether it is
> operating within a fence epoch or not. I'm not sure how to
> implement any
> sort of error checking to cover this case, as the user could
> follow a fence
> with either RMA calls or some other synchronization
> primitives (POST-START
> or LOCK) or even protected local access. It was my
> understanding that the
> ASSERT flags were meant to be hints to the implementation and
> not required
> by the caller for proper operation.
> Can you help clear this up?  Is the test wrong or are we
> actually required
> to handle this situation?
> thanks,
> doug miller
More information about the mpich2-dev mailing list
