[mpich2-dev] MPI_COMM_WORLD failed when using pio-bench on PVFS
    汪迪
    otheryou at yahoo.cn
    Mon Apr 13 10:46:49 CDT 2009
Sorry I made a mistake on previous email. The http address is http://newsgroups.derkeiler.com/Archive/Comp/comp.parallel.mpi/2006-04/msg00044.html
--- 09年4月13日,周一, 汪迪 <otheryou at yahoo.cn> 写道:
发件人: 汪迪 <otheryou at yahoo.cn>
主题: RE: [mpich2-dev] MPI_COMM_WORLD failed when using pio-bench on PVFS
收件人: "Rajeev Thakur" <thakur at mcs.anl.gov>
抄送: "'MPICH2-developer mailling-list'" <mpich2-dev at mcs.anl.gov>
日期: 2009,413,周一,11:20下午
Hi,  Rajeev
It is not a problem of my MPI installation, it is a problem of pio-bench. Actually I found someone who has the same problem here: http://newsgroups.derkeiler.com/Archive/Comp/comp.parallel.mpi/2006-04/msg00046.html. And I tried his source code on my own machine, the other MPI error occurs when running on root (while not on root it did not give the error detail).
I think it is due to the dynamically allocated address semantic incompatible. The gcc I use is (Ubuntu 4.3.2-1ubuntu12) 4.3.2.  If you can run pio-bench without any problem, I want to know the edition of the gcc you use.  Thanks.
By the way I check the pio-bench source code and know the only statement that causes this problem is:
 MPI_Bcast( qlist_entry(p, ap_module, link), sizeof(ap_module), MPI_BYTE, 0, MPI_COMM_WORLD);   in main
 function of pio-bench.c.  Can you give me any suggestion on modify this code? As I might as well consider modifying the pio-bench source code if changing the gcc does not work.
--- 09年3月27日,周五, Rajeev Thakur <thakur at mcs.anl.gov> 写道:
发件人: Rajeev Thakur <thakur at mcs.anl.gov>
收件人: "'??'" <otheryou at yahoo.cn>
日期: 2009,327,周五,2:51上午
What do you mean by "I configure PVFS system server on my own
laptop, which uses MPICH2 as its trove storage system implementation"? You have
installed MPICH2 and PVFS as two separate components, right? Does pio-bench
work if you make it access a local file directly via the Linux file
system?
Rajeev
Sent: Thursday, March 26, 2009 12:05 AM
To: Rajeev
  Thakur
Cc: MPICH2-developer mailling-list
Subject: RE:
  PVFS
Hi,  Rajeev
Other MPI programs runs
        correctly, including cpi under examples folder.
gxwangdi at WANGDI ~/D/m/examples>
        pwd
~/Downloads/mpich2-1.0.8/examples
gxwangdi at WANGDI
        ~/D/m/examples> mpd &
        mpdtrace
WANGDI
gxwangdi at WANGDI ~/D/m/examples> which
        mpiexec
/usr/local/bin/mpiexec
        mpiexec -n 10 ./cpi
Process 2 of 10 is on WANGDI
Process 1 of 10
        is on WANGDI
Process 0 of 10 is on WANGDI
Process 6 of 10 is on
        WANGDI
Process 4 of 10 is on WANGDI
Process 9 of 10 is on
        WANGDI
Process 3 of 10 is on WANGDI
Process 7 of 10 is on
        WANGDI
Process 8 of 10 is on WANGDI
Process 5 of 10 is on
        WANGDI
pi is approximately 3.1415926544231256, Error is
        0.0000000008333325
wall clock time = 0.012229
Thanks for your
        suggestion, I run make testing in the top directory of mpich2.
        There is a test that do not pass:
xwangdi at WANGDI ~/D/mpich2-1.0.8>
        mpd &
gxwangdi at WANGDI ~/D/mpich2-1.0.8> make testing
(cd
        test && make testing)
make[1]: Entering directory
        `/home/gxwangdi/Downloads/mpich2-1.0.8/test'
(NOXMLCLOSE=YES
        && export NOXMLCLOSE && cd mpi && make
        testing)
make[2]: Entering directory
        `/home/gxwangdi/Downloads/mpich2-1.0.8/test/mpi'
./runtests -srcdir=.
        -tests=testlist \
        -mpiexec=/usr/local/bin/mpiexec \
               -xmlfile=summary.xml
Looking in
        ./testlist
Processing directory attr
Looking in
        ./attr/testlist
Processing directory coll
Looking in
        ./coll/testlist
Processing directory comm
Looking in
        ./comm/testlist
Some programs (cmsplit) may still be running:
pids
        = 2279
The executable (cmsplit) will not be removed.
Processing
        directory datatype
Looking in ./datatype/testlist
Processing
        directory errhan
Looking in ./errhan/testlist
        group
Looking in ./group/testlist
        info
Looking in ./info/testlist
        init
Looking in ./init/testlist
        pt2pt
Looking in ./pt2pt/testlist
Some programs (sendrecv3) may
        still be running:
pids = 4049
The executable (sendrecv3) will not
        be removed.
Processing directory rma
Looking in
        ./rma/testlist
Some programs (transpose3) may still be
        running:
pids = 5713
The executable (transpose3) will not be
        removed.
Processing directory spawn
Looking in
        ./spawn/testlist
Processing directory topo
Looking in
        ./topo/testlist
Processing directory perf
Looking in
        ./perf/testlist
Processing directory io
Looking in
        ./io/testlist
Processing directory cxx
Looking in
        ./cxx/testlist
Looking in
        ./cxx/attr/testlist
Processing directory pt2pt
Looking in
        ./cxx/pt2pt/testlist
Failed to build bsend1cxx; make[3]: Entering
        directory
        `/home/gxwangdi/Downloads/mpich2-1.0.8/test/mpi/cxx/pt2pt'
/usr/local/bin/mpicxx
        -DHAVE_CONFIG_H -I. -I. -I../../include -I./../../include -c
        bsend1cxx.cxx
bsend1cxx.cxx: In function ‘int main(int,
        char**)’:
bsend1cxx.cxx:81: error: ‘strcmp’ was not declared in this
        scope
bsend1cxx.cxx:91: error: ‘strcmp’ was not declared in this
        scope
make[3]: *** [bsend1cxx.o] Error 1
make[3]: Leaving
        directory
Processing
        directory comm
Looking in ./cxx/comm/testlist
        coll
Looking in ./cxx/coll/testlist
        init
Looking in ./cxx/init/testlist
        info
Looking in ./cxx/info/testlist
        datatype
Looking in ./cxx/datatype/testlist
        io
Looking in ./cxx/io/testlist
        spawn
Looking in ./cxx/spawn/testlist
        rma
Looking in ./cxx/rma/testlist
        errors
Looking in ./errors/testlist
        attr
Looking in ./errors/attr/testlist
        coll
Looking in ./errors/coll/testlist
        comm
Looking in ./errors/comm/testlist
        group
Looking in ./errors/group/testlist
        pt2pt
Looking in ./errors/pt2pt/testlist
        topo
Looking in ./errors/topo/testlist
        rma
Looking in ./errors/rma/testlist
        spawn
Looking in ./errors/spawn/testlist
        io
Looking in ./errors/io/testlist
        cxx
Looking in ./errors/cxx/testlist
        errhan
Looking in ./errors/cxx/errhan/testlist
Processing
        directory io
Looking in ./errors/cxx/io/testlist
Processing
        directory threads
Looking in ./threads/testlist
Processing
        directory pt2pt
Looking in ./threads/pt2pt/testlist
Processing
        directory comm
Looking in ./threads/comm/testlist
1 tests failed
        out of 385
Details in
        /home/gxwangdi/Downloads/mpich2-1.0.8/test/mpi/summary.xml
make[2]:
        Leaving directory
(XMLFILE=../mpi/summary.xml
        && XMLCONTINUE=YES && \
    export
        XMLFILE && export XMLCONTINUE && \
        cd commands && make testing)
        `/home/gxwangdi/Downloads/mpich2-1.0.8/test/commands'
make[2]:
        Nothing to be done for `testing'.
make[2]: Leaving directory
make[1]:
        Leaving directory
And the attachment
        is the /home/gxwangdi/Downloads/mpich2-1.0.8/test/mpi/summary.xml file,
        it is too long to paste all content here. I can not understand what is
        the problem yet.
Subject: RE: [mpich2-dev]
To:
          otheryou at yahoo.cn, mpich2-dev at mcs.anl.gov
Date:
          2009,3/26,Thursday,2:41
          Do the other MPICH2 tests run, such as
          the cpi example in the examples directory? If you run "make testing"
          in the top-level mpich2 directory it will run the entire tests suite
          in test/mpi (can take more than an hour).
          Rajeev
            [mailto:mpich2-dev-bounces at mcs.anl.gov] On Behalf Of
Sent: Wednesday, March 25, 2009 12:11
            AM
To: MPICH2-developer mailling-list
Subject:
            PVFS
                  my own laptop, which uses MPICH2 as its trove storage system
                  implementation.  And now I tend to use pio-bench to get
                  the trace of the server. It works as I set the number of
                  process as 1, but when I set the number of process to more
                  than 1, it does not work all the time. It tips the
                  MPI_COMM_WORLD failed, but I run hostname command with MPI and
                  it works. It is peculiar. I check the MPICH2 document and find
                  no particular configuration for single host MPI deployment. Do
                  I do anything wrong?
 By the way my laptop is
                  IBM i386 architecture and CPU is intel centrino2 vPro, OS
                  UBUNTU 8.10, MPICH2 1.0.8 is installed by default under
                  /usr/local, and pvfs2.7.1 is under /root/pvfs-install/.
gxwangdi at WANGDI:~/Desktop/pio-bench$ sudo mpiexec -n 1
                  ./pio-bench
[sudo] password for gxwangdi:
File under
                  test: /mnt/pvfs2/ftpaccess
Number of Processes: 1
Sync:
                  off
Averaging: Off
the nested strided pattern needs to
                  be run with an even amount of processes
file pio-bench.c,
                  line 586: access pattern initialization error:
                  -1
                  4 ./pio-bench
Fatal error in MPI_Barrier: Other MPI error,
                  error stack:
MPI_Barrier(406)..........................:
                  MPI_Barrier(MPI_COMM_WORLD)
failed
MPIR_Barrier(77)..........................:
MPIC_Sendrecv(126)........................:
MPIC_Wait(270)............................:
MPIDI_CH3i_Progress_wait(215).............:
                  an error occurred while
handling an event returned by
                  MPIDU_Sock_Wait()
MPIDI_CH3I_Progress_handle_sock_event(420):
MPIDU_Socki_handle_read(637)..............:
                  connection failure
(set=0,sock=1,errno=104:Connection reset
                  by peer)[cli_0]: aborting job:
                  Other MPI error, error
                  stack:
failed
                  MPIDU_Sock_Wait()
MPIDU_Socki_handle_readFatal
                  error in MPI_Bcast: Other MPI error,
                  error
stack:
MPI_Bcast(786)............................:
                  MPI_Bcast(buf=0x1fd6ca78,
count=20, MPI_BYTE, root=0,
                  MPI_COMM_WORLD)
                  failed
MPIR_Bcast(198)...........................:
MPIC_Recv(81).............................:
                  MPIDU_Sock_Wait()
MPIDI_CH3I_Progress_handle_sock_event(456):
adjust_iov(973)...........................:
                  ch3|sock|immedread
0x1e5a0d60 0x1f329978
                  0x1f3258d0
MPIDU_Sock_readv(455).....................: the
                  supplied buffer contains
invalid memory
                  (set=0,sock=1,errno=14:Bad address)[cli_1]: aborting
                  job:
Fatal error in MPI_Bcast: Other MPI error, error
                  stack:
                  MPI_COMM_WORLD)
                  failed
MPIC_Wait(270)............................(637)..............:
connection
                  failure (set=0,sock=1,errno=104:Connection reset by
                  peer)
MPIDI_CH3i_Progress_wait(215).............: an
                  MPIDU_Sock_Wait()
                  ch3|sock|immedread
                  0x1f3258d0
invalid memory
Fatal error in
                  stack:
                  MPI_COMM_WORLD)
                  failed
                  MPIDU_Sock_Wait()
                  ch3|sock|immedread
0x1e5a0d60 0x1eb9f978
                  0x1eb9b8d0
invalid memory
                  (set=0,sock=1,errno=14:Bad address)[cli_2]: aborting
                  job:
                  stack:
MPI_Bcast(786)........................so....:
                  MPI_COMM_WORLD)
                  failed
                  MPIDU_Sock_Wait()
                  ch3|sock|immedread
                  0x1eb9b8d0
invalid memory
rank 1 in job 9
                  WANGDI_59039   caused collective abort of all
                  ranks
  exit status of rank 1: return code 1
rank 0
                  in job 9  WANGDI_59039   caused collective
                  abort of all ranks
  exit status of rank 0: return
                  code 1
                  4
                  hostname
WANGDI
WANGDI
WANGDI
WANGDI
and
                  my pio-bench.conf file is like:
Testfile
                  "/mnt/pvfs2/ftpaccess"
OutputToFile
                  "/home/gxwangdi/Desktop/pio-bench/results/result"
<ap_module>
ModuleName
                  "Nested Strided (read)"
ModuleReps 3
ModuleSettleTime
                  5
</ap_module>
<ap_module>so
ModuleName
                  "Nested Strided (write)"
ModuleReps 3
ModuleSettleTime
                  5
</ap_module>
<ap_module>
ModuleName
                  "Nested Strided (read-modify-write)"
ModuleReps
                  3
ModuleSettleTime
                  5
</ap_module>
<ap_module>
ModuleName
                  "Nested Strided (re-read)"
ModuleReps 3
ModuleSettleTime
                  5
</ap_module>
<ap_module>
ModuleName
                  "Nested Strided (re-write)"
ModuleReps
                  3
ModuleSettleTime 5
</ap_module>
Also I
                  use another file that is not under /mnt/pvfs2 for test, it
                  tips like below:
                  sudo mpiexec -n 4 ./pio-bench
                  stack:
failed
                  MPIDU_Sock_Wait()
                  connection failure
                  stack:
failed
                  MPIDU_Sock_Wait()
                  error
stack:
                  MPI_Bcast(buf=0x1f60fad0,
                  MPI_COMM_WORLD)
                  failed
                  MPIDU_Sock_Wait()
                  ch3|sock|immedread
0x1e5a0d60 0x1f525978
                  0x1f5218d0
invalid memory
                  job:
                  stack:
                  MPI_COMM_WORLD)
                  failed
connection
                  peer)
                  MPIDU_Sock_Wait()
                  ch3|sock|immedread
                  0x1f5218d0
invalid memory
Fatal error in
                  stack:
                  MPI_COMM_WORLD)
                  failed
                  MPIDU_Sock_Wait()
                  ch3|sock|immedread
0x1e5a0d60 0x202d2978
                  0x202ce8d0
invalid memory
                  job:
                  stack:
                  MPI_COMM_WORLD)
                  failed
                  MPIDU_Sock_Wait()
                  ch3|sock|immedread
                  0x202ce8d0
invalid memory
rank 2 in job 11
                  ranks
  exit status of rank 2: return code 1
rank 1
                  in job 11  WANGDI_59039   caused collective
                  abort of all ranks
                  code 1
rank 0 in job 11  WANGDI_59039
                  caused collective abort of all ranks
  exit status of
                  rank 0: return code 1
The MPI_COMM_WORLD failed
                  again but it caused collective abort of all
ranks at the
                  end, which is a little bit different, as it has no
                  syslog
for pio-bench to check, I do not understand what
                  happens and I can not
solve this problem.
Appreciate
                  your responses.
            好玩贺卡等你发,邮箱贺卡全新上线!
  好玩贺卡等你发,邮箱贺卡全新上线!
        好玩贺卡等你发,邮箱贺卡全新上线!
      ___________________________________________________________
  好玩贺卡等你发,邮箱贺卡全新上线!
http://card.mail.cn.yahoo.com/
URL: <https://lists.mcs.anl.gov/mailman/private/mpich2-dev/attachments/20090413/312b759a/attachment-0001.htm>
More information about the mpich2-dev
