[mpich2-dev] Update resized.c code to match the comments.
Bob Cernohous bobc at us.ibm.com
Fri Apr 10 16:19:47 CDT 2009
mpich2-dev-bounces at mcs.anl.gov wrote on 04/09/2009 04:56:03 PM:
> On Thu, Apr 09, 2009 at 04:10:06PM -0500, Bob Cernohous wrote:
> > Hi,
> > The io/resized.c test is failing in 1.1b1.   It looks like the code
> > doesn't match the comments.  It says use an lb at 0, but sets lb to
> > 4.  If I change the code, it runs fine.  Comments?
> Hi Bob.  Yeah, sorry, the comment is wrong.  The code is correct in
> that it finds a tricky case with respect to tiling of types.  If you
> set the LB to 0 it's not a very tricky type at all :>
> It took us a bunch of iterations after introducing an optimization in
> adio/common to get this right.   We didn't have a test for resized
> types before we introduced the optimization, but if we did, it would
> have failed, too.  adio/ad_bgl is based on this older version of
> adio/common, so it's failing the resized test.
> How would you like to play this one, Bob?   I can tell you our svn
> revisions of interest and you can either port these into adio/ad_bgl
> or you can try to debug adio/ad_bgl as-is.
> Honestly, I don't know which will be more work.
> The svn revisions of interest went in over the summer of 2008:
> r3219
> r3193
> r1001
> r983
> r988
> r984
> r968
> r960
> r958
> r956
> Sorry I don't have a better answer for you.
> ==rob
> Rob Latham
> Mathematics and Computer Science Division
> Argonne National Lab, IL USA
I got this working.  The key was Wei-keng Liao's + misc changes in
ad_write_str.c.
I picked up relevant _str, _coll, and ad_aggregate changes.  It wasn't too
bad.  I still need to check the rest of ad_bgl.
Thanks.
URL: <https://lists.mcs.anl.gov/mailman/private/mpich2-dev/attachments/20090410/6b338242/attachment.htm>
More information about the mpich2-dev mailing list
