[mpich2-dev] MPI_COMM_WORLD failed when using pio-bench on PVFS
汪迪
otheryou at yahoo.cn
Wed Apr 1 01:23:59 CDT 2009
Hi, Thakur
I install MPICH2 by default configuration, and I install PVFS as root on that MPI installation, and again I install MPICH2, having "--with-pvfs=pvfs-route" option. I verify my PVFS installation and it works fine, and once I activate PVFS, the mpd would start automatically backend. I verify my installation these two days, it works fine on any mpi programs including the cpi in the examples directory, except pio-bench and noncontig workbench. pio-bench seems work fine if not running on mpi, and access a common file in linux file system. Even if it runs on mpich2, if the number of process is 1 it also works fine, so does noncontig by the way. The only failure occurs when the number of process is more than 1 (and more than 2 for noncontig).
gxwangdi at WANGDI:~/Desktop/pio-bench$ ./pio-bench
File under test: /home/gxwangdi/Desktop/ftpaccess
Number of Processes: 1
Sync: off
Averaging: Off
Sleeping for 5 seconds
Averaging: Off
Averaging: Off
Averaging: Off
Averaging: Off
gxwangdi at WANGDI:~/Desktop/pio-bench$ mpd &
[1] 13777
gxwangdi at WANGDI:~/Desktop/pio-bench$ mpiexec -n 4 ./pio-bench
Fatal error in MPI_Barrier: Other MPI error, error stack:
MPI_Barrier(406)..........................: MPI_Barrier(MPI_COMM_WORLD) failed
MPIR_Barrier(77)..........................:
MPIC_Sendrecv(126)........................:
MPIC_Wait(270)............................:
MPIDI_CH3i_Progress_wait(215).............: an error occurred while handling an event returned by MPIDU_Sock_Wait()
MPIDI_CH3I_Progress_handle_sock_event(420):
MPIDU_Socki_handle_read(637)..............: connection failure (set=0,sock=2,errno=104:Connection reset by peer)[cli_0]: aborting job:
MPIDU_Socki_handle_readFatal error in MPI_Bcast: Other MPI error, error stack:
MPI_Bcast(786)............................: MPI_Bcast(buf=0x1f2efa98, count=20, MPI_BYTE, root=0, MPI_COMM_WORLD) failed
MPIR_Bcast(198)...........................:
MPIC_Recv(81).............................:
MPIDI_CH3I_Progress_handle_sock_event(456):
adjust_iov(973)...........................: ch3|sock|immedread 0x1e5a0d60 0x1fee6978 0x1fee28d0
MPIDU_Sock_readv(455).....................: the supplied buffer contains invalid memory (set=0,sock=1,errno=14:Bad address)[cli_1]: aborting job:
MPIC_Wait(270)............................(637)..............: connection failure (set=0,sock=2,errno=104:Connection reset by peer)
adjust_iov(973)...........................: ch3|sock|immedread 0x1e5a11a4 0x1fdec978 0x1fde88d0
MPIDU_Sock_readv(455).....................: the supplied buffer contains invalid memory (set=0,sock=1,errno=14:Bad address)[cli_2]: aborting job:
rank 2 in job 1 WANGDI_57913 caused collective abort of all ranks
exit status of rank 2: return code 1
rank 1 in job 1 WANGDI_57913 caused collective abort of all ranks
exit status of rank 1: killed by signal 9
rank 0 in job 1 WANGDI_57913 caused collective abort of all ranks
exit status of rank 0: return code 1
gxwangdi at WANGDI:~/Desktop/pio-bench$ sudo mpd &
[1] 22125
gxwangdi at WANGDI:~/Desktop/pio-bench$ sudo mpiexec -n 4 ./pio-bench
[sudo] password for gxwangdi:
MPI_Bcast(786)............................: MPI_Bcast(buf=0x1eed1ad0, count=20, MPI_BYTE, root=0, MPI_COMM_WORLD) failed
adjust_iov(973)...........................: ch3|sock|immedread 0x1e5a0d60 0x1ecee978 0x1ecea8d0
MPIC_Wait(270)............................Fatal error in MPI_Barrier: Other MPI error, error stack:
MPIDU_Socki_handle_read(637)..............: connection failure (set=0,sock=1,errno=104:Connection reset by peer)[cli_0]: aborting job:
MPIDU_Socki_handle_read:
adjust_iov(973)...........................: ch3|sock|immedread 0x1e5a0d60 0x1f9eb978 0x1f9e78d0
rank 2 in job 1 WANGDI_49008 caused collective abort of all ranks
rank 1 in job 1 WANGDI_49008 caused collective abort of all ranks
exit status of rank 1: return code 1
rank 0 in job 1 WANGDI_49008 caused collective abort of all ranks
the pio-bench.conf is like below:
#Testfile "/mnt/pvfs2/ftpaccess"
TestFile "/home/gxwangdi/Desktop/ftpaccess"
OutputToFile "/home/gxwangdi/Desktop/pio-bench/results/result"
<ap_module>
ModuleName "Simple Strided (read)"
ModuleReps 3
ModuleSettleTime 5
</ap_module>
<ap_module>
ModuleName "Nested Strided (write)"
ModuleReps 3
ModuleSettleTime 5
</ap_module>
<ap_module>
ModuleName "Simple Strided (read-modify-write)"
ModuleReps 3
ModuleSettleTime 5
</ap_module>
<ap_module>
ModuleName "Nested Strided (re-read)"
ModuleReps 3
ModuleSettleTime 5
</ap_module>
And also the mpich2 can not pass the test all the time. I try to start mpd in normal/root mode, activate pvfs server instead, the results are the same.
root at WANGDI:/home/gxwangdi/Downloads/mpich2-1.0.8# make testing
(cd test && make testing)
make[1]: Entering directory `/home/gxwangdi/Downloads/mpich2-1.0.8/test'
(NOXMLCLOSE=YES && export NOXMLCLOSE && cd mpi && make testing)
make[2]: Entering directory `/home/gxwangdi/Downloads/mpich2-1.0.8/test/mpi'
./runtests -srcdir=. -tests=testlist \
-mpiexec=/usr/local/bin/mpiexec \
-xmlfile=summary.xml
Looking in ./testlist
Processing directory attr
Looking in ./attr/testlist
Processing directory coll
Looking in ./coll/testlist
Processing directory comm
Looking in ./comm/testlist
Processing directory datatype
Looking in ./datatype/testlist
Processing directory errhan
Looking in ./errhan/testlist
Processing directory group
Looking in ./group/testlist
Processing directory info
Looking in ./info/testlist
Processing directory init
Looking in ./init/testlist
Processing directory pt2pt
Looking in ./pt2pt/testlist
Processing directory rma
Looking in ./rma/testlist
Processing directory spawn
Looking in ./spawn/testlist
Processing directory topo
Looking in ./topo/testlist
Processing directory perf
Looking in ./perf/testlist
Processing directory io
Looking in ./io/testlist
Processing directory cxx
Looking in ./cxx/testlist
Looking in ./cxx/attr/testlist
Looking in ./cxx/pt2pt/testlist
Failed to build bsend1cxx; make[3]: Entering directory `/home/gxwangdi/Downloads/mpich2-1.0.8/test/mpi/cxx/pt2pt'
/usr/local/bin/mpicxx -DHAVE_CONFIG_H -I. -I. -I../../include -I./../../include -c bsend1cxx.cxx
bsend1cxx.cxx: In function ‘int main(int, char**)’:
bsend1cxx.cxx:81: error: ‘strcmp’ was not declared in this scope
bsend1cxx.cxx:91: error: ‘strcmp’ was not declared in this scope
make[3]: *** [bsend1cxx.o] Error 1
make[3]: Leaving directory `/home/gxwangdi/Downloads/mpich2-1.0.8/test/mpi/cxx/pt2pt'
Looking in ./cxx/comm/testlist
Looking in ./cxx/coll/testlist
Looking in ./cxx/init/testlist
Looking in ./cxx/info/testlist
Looking in ./cxx/datatype/testlist
Looking in ./cxx/io/testlist
Looking in ./cxx/spawn/testlist
Looking in ./cxx/rma/testlist
Processing directory errors
Looking in ./errors/testlist
Looking in ./errors/attr/testlist
Looking in ./errors/coll/testlist
Looking in ./errors/comm/testlist
Looking in ./errors/group/testlist
Looking in ./errors/pt2pt/testlist
Looking in ./errors/topo/testlist
Looking in ./errors/rma/testlist
Looking in ./errors/spawn/testlist
Looking in ./errors/io/testlist
Looking in ./errors/cxx/testlist
Looking in ./errors/cxx/errhan/testlist
Looking in ./errors/cxx/io/testlist
Processing directory threads
Looking in ./threads/testlist
Looking in ./threads/pt2pt/testlist
Looking in ./threads/comm/testlist
1 tests failed out of 385
Details in /home/gxwangdi/Downloads/mpich2-1.0.8/test/mpi/summary.xml
make[2]: Leaving directory `/home/gxwangdi/Downloads/mpich2-1.0.8/test/mpi'
(XMLFILE=../mpi/summary.xml && XMLCONTINUE=YES && \
export XMLFILE && export XMLCONTINUE && \
cd commands && make testing)
make[2]: Entering directory `/home/gxwangdi/Downloads/mpich2-1.0.8/test/commands'
make[2]: Nothing to be done for `testing'.
make[2]: Leaving directory `/home/gxwangdi/Downloads/mpich2-1.0.8/test/commands'
make[1]: Leaving directory `/home/gxwangdi/Downloads/mpich2-1.0.8/test'
I can not figure out the problem from the summary.xml. I attach my configure.log, config.log, make.log, install.log and summary.xml in the attachment.
--- 09年3月27日,周五, Rajeev Thakur <thakur at mcs.anl.gov> 写道:
发件人: Rajeev Thakur <thakur at mcs.anl.gov>
主题: RE: [mpich2-dev] MPI_COMM_WORLD failed when using pio-bench on PVFS
收件人: "'??'" <otheryou at yahoo.cn>
抄送: "'MPICH2-developer mailling-list'" <mpich2-dev at mcs.anl.gov>
日期: 2009,327,周五,2:51上午
What do you mean by "I configure PVFS system server on my own
laptop, which uses MPICH2 as its trove storage system implementation"? You have
installed MPICH2 and PVFS as two separate components, right? Does pio-bench
work if you make it access a local file directly via the Linux file
system?
Rajeev
Sent: Thursday, March 26, 2009 12:05 AM
To: Rajeev
Thakur
Cc: MPICH2-developer mailling-list
Subject: RE:
PVFS
Hi, Rajeev
Other MPI programs runs
correctly, including cpi under examples folder.
gxwangdi at WANGDI ~/D/m/examples>
pwd
~/Downloads/mpich2-1.0.8/examples
gxwangdi at WANGDI
~/D/m/examples> mpd &
mpdtrace
WANGDI
gxwangdi at WANGDI ~/D/m/examples> which
mpiexec
mpiexec -n 10 ./cpi
Process 2 of 10 is on WANGDI
Process 1 of 10
is on WANGDI
Process 0 of 10 is on WANGDI
Process 6 of 10 is on
WANGDI
Process 4 of 10 is on WANGDI
Process 9 of 10 is on
WANGDI
Process 3 of 10 is on WANGDI
Process 7 of 10 is on
WANGDI
Process 8 of 10 is on WANGDI
Process 5 of 10 is on
WANGDI
pi is approximately 3.1415926544231256, Error is
0.0000000008333325
wall clock time = 0.012229
Thanks for your
suggestion, I run make testing in the top directory of mpich2.
There is a test that do not pass:
xwangdi at WANGDI ~/D/mpich2-1.0.8>
mpd &
gxwangdi at WANGDI ~/D/mpich2-1.0.8> make testing
(cd
(NOXMLCLOSE=YES
testing)
-tests=testlist \
Looking in
./testlist
Looking in
./attr/testlist
Looking in
./coll/testlist
Looking in
./comm/testlist
Some programs (cmsplit) may still be running:
pids
= 2279
The executable (cmsplit) will not be removed.
Processing
directory datatype
Processing
directory errhan
group
info
init
pt2pt
Some programs (sendrecv3) may
still be running:
pids = 4049
The executable (sendrecv3) will not
be removed.
Looking in
./rma/testlist
Some programs (transpose3) may still be
running:
pids = 5713
The executable (transpose3) will not be
removed.
Looking in
./spawn/testlist
Looking in
./topo/testlist
Looking in
./perf/testlist
Looking in
./io/testlist
Looking in
./cxx/testlist
Looking in
./cxx/attr/testlist
Looking in
directory
bsend1cxx.cxx
char**)’:
scope
scope
make[3]: Leaving
directory
Processing
directory comm
coll
init
info
datatype
io
spawn
rma
errors
attr
coll
comm
group
pt2pt
topo
rma
spawn
io
cxx
errhan
Processing
directory io
Processing
directory threads
Processing
directory pt2pt
Processing
directory comm
1 tests failed
out of 385
Details in
make[2]:
Leaving directory
export
make[2]:
make[1]:
Leaving directory
And the attachment
is the /home/gxwangdi/Downloads/mpich2-1.0.8/test/mpi/summary.xml file,
it is too long to paste all content here. I can not understand what is
the problem yet.
Subject: RE: [mpich2-dev]
To:
otheryou at yahoo.cn, mpich2-dev at mcs.anl.gov
Date:
2009,3/26,Thursday,2:41
Do the other MPICH2 tests run, such as
the cpi example in the examples directory? If you run "make testing"
in the top-level mpich2 directory it will run the entire tests suite
in test/mpi (can take more than an hour).
Rajeev
[mailto:mpich2-dev-bounces at mcs.anl.gov] On Behalf Of
Sent: Wednesday, March 25, 2009 12:11
AM
To: MPICH2-developer mailling-list
Subject:
PVFS
my own laptop, which uses MPICH2 as its trove storage system
implementation. And now I tend to use pio-bench to get
the trace of the server. It works as I set the number of
process as 1, but when I set the number of process to more
than 1, it does not work all the time. It tips the
MPI_COMM_WORLD failed, but I run hostname command with MPI and
it works. It is peculiar. I check the MPICH2 document and find
no particular configuration for single host MPI deployment. Do
I do anything wrong?
By the way my laptop is
IBM i386 architecture and CPU is intel centrino2 vPro, OS
UBUNTU 8.10, MPICH2 1.0.8 is installed by default under
/usr/local, and pvfs2.7.1 is under /root/pvfs-install/.
gxwangdi at WANGDI:~/Desktop/pio-bench$ sudo mpiexec -n 1
./pio-bench
File under
test: /mnt/pvfs2/ftpaccess
Sync:
off
Averaging: Off
the nested strided pattern needs to
be run with an even amount of processes
file pio-bench.c,
line 586: access pattern initialization error:
-1
4 ./pio-bench
error stack:
failed
MPIDU_Sock_Wait()
connection failure
stack:
failed
MPIDU_Sock_Wait()
error
stack:
MPI_Bcast(buf=0x1fd6ca78,
MPI_COMM_WORLD)
failed
MPIDU_Sock_Wait()
ch3|sock|immedread
0x1e5a0d60 0x1f329978
0x1f3258d0
invalid memory
job:
stack:
MPI_COMM_WORLD)
failed
connection
peer)
MPIDU_Sock_Wait()
ch3|sock|immedread
0x1f3258d0
invalid memory
Fatal error in
stack:
MPI_COMM_WORLD)
failed
MPIDU_Sock_Wait()
ch3|sock|immedread
0x1e5a0d60 0x1eb9f978
0x1eb9b8d0
invalid memory
job:
stack:
MPI_Bcast(786)........................so....:
MPI_COMM_WORLD)
failed
MPIDU_Sock_Wait()
ch3|sock|immedread
0x1eb9b8d0
invalid memory
rank 1 in job 9
WANGDI_59039 caused collective abort of all
ranks
rank 0
in job 9 WANGDI_59039 caused collective
abort of all ranks
code 1
4
hostname
WANGDI
WANGDI
WANGDI
WANGDI
and
my pio-bench.conf file is like:
Testfile
OutputToFile
<ap_module>
ModuleName
"Nested Strided (read)"
ModuleReps 3
ModuleSettleTime
5
</ap_module>
<ap_module>so
ModuleName
ModuleReps 3
ModuleSettleTime
5
</ap_module>
<ap_module>
ModuleName
"Nested Strided (read-modify-write)"
ModuleReps
3
ModuleSettleTime
5
</ap_module>
<ap_module>
ModuleName
ModuleReps 3
ModuleSettleTime
5
</ap_module>
<ap_module>
ModuleName
"Nested Strided (re-write)"
ModuleReps
3
ModuleSettleTime 5
</ap_module>
Also I
use another file that is not under /mnt/pvfs2 for test, it
tips like below:
stack:
failed
MPIDU_Sock_Wait()
connection failure
stack:
failed
MPIDU_Sock_Wait()
error
stack:
MPI_Bcast(buf=0x1f60fad0,
MPI_COMM_WORLD)
failed
MPIDU_Sock_Wait()
ch3|sock|immedread
0x1e5a0d60 0x1f525978
0x1f5218d0
invalid memory
job:
stack:
MPI_COMM_WORLD)
failed
connection
peer)
MPIDU_Sock_Wait()
ch3|sock|immedread
0x1f5218d0
invalid memory
Fatal error in
stack:
MPI_COMM_WORLD)
failed
MPIDU_Sock_Wait()
ch3|sock|immedread
0x1e5a0d60 0x202d2978
0x202ce8d0
invalid memory
job:
stack:
MPI_COMM_WORLD)
failed
MPIDU_Sock_Wait()
ch3|sock|immedread
0x202ce8d0
invalid memory
rank 2 in job 11
ranks
rank 1
in job 11 WANGDI_59039 caused collective
abort of all ranks
code 1
rank 0 in job 11 WANGDI_59039
exit status of
The MPI_COMM_WORLD failed
again but it caused collective abort of all
ranks at the
end, which is a little bit different, as it has no
syslog
for pio-bench to check, I do not understand what
happens and I can not
solve this problem.
Appreciate
your responses.
好玩贺卡等你发,邮箱贺卡全新上线!
好玩贺卡等你发,邮箱贺卡全新上线!
___________________________________________________________
好玩贺卡等你发,邮箱贺卡全新上线!
http://card.mail.cn.yahoo.com/
URL: <https://lists.mcs.anl.gov/mailman/private/mpich2-dev/attachments/20090401/a9e936fe/attachment-0001.htm>
Type: text/x-log
Desc: not available
URL: <https://lists.mcs.anl.gov/mailman/private/mpich2-dev/attachments/20090401/a9e936fe/attachment-0005.bin>
Type: text/x-log
Desc: not available
URL: <https://lists.mcs.anl.gov/mailman/private/mpich2-dev/attachments/20090401/a9e936fe/attachment-0006.bin>
Type: text/x-log
Desc: not available
URL: <https://lists.mcs.anl.gov/mailman/private/mpich2-dev/attachments/20090401/a9e936fe/attachment-0007.bin>
Type: text/x-log
Desc: not available
URL: <https://lists.mcs.anl.gov/mailman/private/mpich2-dev/attachments/20090401/a9e936fe/attachment-0008.bin>
Type: text/xml
Desc: not available
URL: <https://lists.mcs.anl.gov/mailman/private/mpich2-dev/attachments/20090401/a9e936fe/attachment-0009.bin>
More information about the mpich2-dev
