[mpich2-dev] status.MPI_ERROR with inactive persistent requests
David Gingold david.gingold at sicortex.com
Fri May 23 12:32:44 CDT 2008
On May 23, 2008, at 1:18 PM, William Gropp wrote:
> The MPI_ERROR field is only changed by the functions that do
> multiple completions.  Here the text (from the new MPI 2.1 document):
> In general, message passing calls do not modify the value of the
> error code field of
> status variables. This field may be updated only by the functions
> in Section 3.7.5 which
> return multiple statuses. The field is updated if and only if such
> function returns with an
> error code of MPI ERR IN STATUS.
> This isn't quite consistent with this text
> An empty status is a status which is set to return tag =
> MPI ANY TAG, source = MPI ANY SOURCE, error = MPI SUCCESS, and is
> also internally
> configured so that calls to MPI GET COUNT and MPI GET ELEMENTS
> return count = 0
> and MPI TEST CANCELLED returns false. We set a status variable to
> empty when the
> value returned by it is not significant. Status is set in this way
> so as to prevent errors due
> to accesses of stale information.
> That last sentence, however, is key - the intent of an empty status
> is to be as valid as any other status returned by the routine.
> Thus, I'd argue that the intent was that the MPI_ERROR field would
> be set only if relevant - thus, only on the multiple completion
> functions.  I view the "may be updated only",  "may be updated",
> and "updated if and only if" in the first quote to take priority.
What threw me off was this additional bit of text in the spec:
"One is allowed to call MPI_TEST with a null or inactive request
argument. In such a case the operation returns with flag = true and
empty status."
But I'll accept your point, particularly as it means I don't need to
fix my code.  :^)
Thanks for the quick response, Bill.
-dg
More information about the mpich2-dev mailing list
