[mpich2-dev] Coverage annotations and mpid_rma.c
William Gropp wgropp at uiuc.edu
Tue May 13 13:45:09 CDT 2008
I've modified and checked in the first 2 of these.  I'll have a
version of the 3rd shortly, with backward compatibility.
Bill
On May 9, 2008, at 2:18 PM, Rajeev Thakur wrote:
> Yes, there should be some annotation for the coverage test. I am ok
> with option 3 where all this gets moved to the upper layer.
> Rajeev
> From: owner-mpich2-dev at mcs.anl.gov [mailto:owner-mpich2-
> dev at mcs.anl.gov] On Behalf Of William Gropp
> Sent: Monday, April 28, 2008 12:31 PM
> To: mpich2-dev at mcs.anl.gov
> Subject: [mpich2-dev] Coverage annotations and mpid_rma.c
> I was looking at some of the files that have substantial uncovered
> sections, and one such file is ch3/src/mpid_rma.c . All of the
> uncovered code in that file is of the form
> if (! initialized) { initialize(); }
> This raises a number of questions:
> 1) Should there be a coverage annotation for this case (e.g.,
> BEGIN_OPTIONALINIT ... END_OPTIONALINIT)?
> 2) In almost all cases, these initializes cannot happen in correct
> code (e.g., some other routine must have been called first, such as
> MPI_Win_create). Should these be marked as BEGIN ERROR HANDLING ..
> END ERROR HANDLING instead? If so, should it be in the #if error
> handling defintions?
> 3) This entire file is used to provide for and make available a
> function table for the RMA functions (except MPID_Win_test). This
> adds an extra function call to all RMA operations, including
> latency-sensitive operations such as lock or put. Would it make
> sense to promote something like this interface into the top-level
> routines (e.g., MPI_Win_lock), perhaps with a macro that would
> basically say "either convert to a specific routine or convert to a
> reference to a standardized function table"? That would then
> eliminate this file from ch3 entirely.
> Bill
> William Gropp
> Paul and Cynthia Saylor Professor of Computer Science
> University of Illinois Urbana-Champaign
William Gropp
URL: <https://lists.mcs.anl.gov/mailman/private/mpich2-dev/attachments/20080513/b3392deb/attachment.htm>
More information about the mpich2-dev mailing list
