[mpich2-dev] [PATCH 2/4] Issue 4120: Fix BlueGene-specific ROMIO to pass a valid recvBuf to MPI_Alltoallv
Jeff Parker
jjparker at us.ibm.com
Sun Mar 30 23:54:10 CDT 2008
Function ADIOI_BGL_Calc_others_req(), which I optimized a long time ago to
use MPI_Alltoallv(), was passing in a recvBuf pointer = 0xFFFFFFFF if there
was nothing to be received. Before the MPI_Aint work, MPI_Alltoallv()
ignored the recvBuf pointer if the recv counts were all zero. But, the
addition of the MPID_Ensure_Aint_fits_in_pointer() sanity checks checks
the send and recv pointers no matter what, so a sane address is required.
I think it is reasonable to send in a sane address, so I changed
ADIOI_BGL_Calc_others_req() to send in a NULL pointer if there is nothing
to receive. This works in both 4 and 8 byte modes. In
ADIOI_BGL_Calc_others_req(), I also changed the pointer arithmetic to
first cast to a new datatype MPI_Puint, which is an unsigned numeric type
that is the size of a pointer. Also added a signed version for future use.
Signed-off-by: Jeff Parker <jjparker at us.ibm.com>
lib/mpi/mpich2/configure.in | 6 +++
lib/mpi/mpich2/src/include/mpi.h.in | 2 +
.../src/mpi/romio/adio/ad_bgl/ad_bgl_aggrs.c | 37 +++++++++++++-------
3 files changed, 32 insertions(+), 13 deletions(-)
diff --git a/lib/mpi/mpich2/configure.in b/lib/mpi/mpich2/configure.in
index a75c2dc..a5abf78 100755
--- a/lib/mpi/mpich2/configure.in
+++ b/lib/mpi/mpich2/configure.in
@@ -4997,6 +4997,12 @@ for type in int long long_long short ; do
break
fi
done
+# Set signed and unsigned pointer type
+MPI_PINT=$MPI_AINT
+MPI_PUINT="unsigned $MPI_AINT"
+AC_SUBST(MPI_PINT)
+AC_SUBST(MPI_PUINT)
if test "$with_aint_size" == "0" ; then
# use default size
AC_MSG_RESULT([Default MPI_Aint $with_aint_size $MPI_SIZEOF_AINT])
diff --git a/lib/mpi/mpich2/src/include/mpi.h.in b/lib/mpi/mpich2/src/include/mpi.h.in
index 8973900..2250b59 100644
--- a/lib/mpi/mpich2/src/include/mpi.h.in
+++ b/lib/mpi/mpich2/src/include/mpi.h.in
@@ -300,6 +300,8 @@ typedef int MPI_Info;
/* Definitions that are determined by configure. */
typedef @MPI_AINT@ MPI_Aint;
+typedef @MPI_PINT@ MPI_Pint;
+typedef @MPI_PUINT@ MPI_Puint;
typedef @MPI_FINT@ MPI_Fint;
#define MPI_AINT_FMT_DEC_SPEC "@MPI_AINT_FMT_DEC_SPEC@"
#define MPI_AINT_FMT_HEX_SPEC "@MPI_AINT_FMT_HEX_SPEC@"
diff --git a/lib/mpi/mpich2/src/mpi/romio/adio/ad_bgl/ad_bgl_aggrs.c b/lib/mpi/mpich2/src/mpi/romio/adio/ad_bgl/ad_bgl_aggrs.c
index 87da3ab..9a710c3 100644
--- a/lib/mpi/mpich2/src/mpi/romio/adio/ad_bgl/ad_bgl_aggrs.c
+++ b/lib/mpi/mpich2/src/mpi/romio/adio/ad_bgl/ad_bgl_aggrs.c
@@ -886,9 +886,9 @@ void ADIOI_BGL_Calc_others_req(ADIO_File fd, int count_my_req_procs,
others_req[i].lens = (int *)
ADIOI_Malloc(count_others_req_per_proc[i]*sizeof(int));
- if ( (unsigned)others_req[i].offsets < (unsigned)recvBufForOffsets )
+ if ( (MPI_Puint)others_req[i].offsets < (MPI_Puint)recvBufForOffsets )
recvBufForOffsets = others_req[i].offsets;
- if ( (unsigned)others_req[i].lens < (unsigned)recvBufForLens )
+ if ( (MPI_Puint)others_req[i].lens < (MPI_Puint)recvBufForLens )
recvBufForLens = others_req[i].lens;
others_req[i].mem_ptrs = (MPI_Aint *)
@@ -903,6 +903,9 @@ void ADIOI_BGL_Calc_others_req(ADIO_File fd, int count_my_req_procs,
others_req[i].lens = NULL;
+ /* If no recv buffer was allocated in the loop above, make it NULL */
+ if ( recvBufForOffsets == (void*)0xFFFFFFFF) recvBufForOffsets = NULL;
+ if ( recvBufForLens == (void*)0xFFFFFFFF) recvBufForLens = NULL;
/* Now send the calculated offsets and lengths to respective processes */
@@ -914,11 +917,11 @@ void ADIOI_BGL_Calc_others_req(ADIO_File fd, int count_my_req_procs,
for (i=0; i<nprocs; i++)
if ( (my_req[i].count) &&
- ((unsigned)my_req[i].offsets <= (unsigned)sendBufForOffsets) )
- sendBufForOffsets = my_req[i].offsets;
+ ((MPI_Puint)my_req[i].offsets <= (MPI_Puint)sendBufForOffsets) )
+ sendBufForOffsets = my_req[i].offsets;
- ((unsigned)my_req[i].lens <= (unsigned)sendBufForLens) )
+ ((MPI_Puint)my_req[i].lens <= (MPI_Puint)sendBufForLens) )
sendBufForLens = my_req[i].lens;
@@ -930,16 +933,20 @@ void ADIOI_BGL_Calc_others_req(ADIO_File fd, int count_my_req_procs,
if ( scounts[i] == 0 )
sdispls[i] = 0;
else
- sdispls[i] = ( (unsigned)my_req[i].offsets -
- (unsigned)sendBufForOffsets ) / sizeof(ADIO_Offset);
+ sdispls[i] = (int)
+ ( ( (MPI_Puint)my_req[i].offsets -
+ (MPI_Puint)sendBufForOffsets ) /
+ (MPI_Puint)sizeof(ADIO_Offset) );
// Receive these offsets from process i.
rcounts[i] = count_others_req_per_proc[i];
if ( rcounts[i] == 0 )
rdispls[i] = 0;
else
- rdispls[i] = ( (unsigned)others_req[i].offsets -
- (unsigned)recvBufForOffsets ) / sizeof(ADIO_Offset);
+ rdispls[i] = (int)
+ ( ( (MPI_Puint)others_req[i].offsets -
+ (MPI_Puint)recvBufForOffsets ) /
/* Exchange the offsets */
@@ -960,16 +967,20 @@ void ADIOI_BGL_Calc_others_req(ADIO_File fd, int count_my_req_procs,
sdispls[i] = 0;
else
- sdispls[i] = ( (unsigned)my_req[i].lens -
- (unsigned)sendBufForLens ) / sizeof(int);
+ ( ( (MPI_Puint)my_req[i].lens -
+ (MPI_Puint)sendBufForLens ) /
+ (MPI_Puint) sizeof(int) );
rdispls[i] = 0;
else
- rdispls[i] = ( (unsigned)others_req[i].lens -
- (unsigned)recvBufForLens ) / sizeof(int);
+ ( ( (MPI_Puint)others_req[i].lens -
+ (MPI_Puint)recvBufForLens ) /
/* Exchange the lengths */
1.5.3.7
More information about the mpich2-dev
