[mpich2-dev] Announcing the availability of MPICH2-1.0.7rc2
Joseph Ratterman
jratt at us.ibm.com
Wed Mar 26 11:13:21 CDT 2008
Now I'm seeing the problem again. The first merge was only with our old
code version that we provided to you so that you could include the dcmfd
device in the code. My current problems are in the codebase from the
merge with our lastest dirver information. These are my flags (pulled
from config.log, so I'm sure they are correct):
'FFLAGS=-I/bgusr/jratt/del/bgp/work/comm/sys/include -fno-underscoring'
'MPICH2LIB_FFLAGS=-g -Wall -O3 -mcpu=450fp2 -mstrict-align
-fno-strict-aliasing -fno-underscoring'
These are what I consider to be the interesting bits of
mpich2/tests/mpi/configure:
1615 # If it is building with MPICH2, set xFLAGS to null, as mpiXX
contains xFLAGS.
1616 if test "$FROM_MPICH2" = "yes" ; then
1617 CFLAGS=""
1618 CXXFLAGS=""
1619 FFLAGS=""
1620 F90FLAGS=""
1621 fi
5746 # Check for strange behavior of Fortran. For example, some
FreeBSD
5747 # systems use f2c to implement f77, and the version of f2c that
they
5748 # use generates TWO (!!!) trailing underscores
5749 # Currently, WDEF is not used but could be...
5750 #
5751 # Eventually, we want to be able to override the choices here
and
5752 # force a particular form. This is particularly useful in
systems
5753 # where a Fortran compiler option is used to force a particular
5754 # external name format (rs6000 xlf, for example).
5755 rm -f conftest*
5756 cat > conftest.f <<EOF
5757 subroutine MY_name( i )
5758 return
5759 end
5760 EOF
5761 # This is the ac_compile line used if LANG_FORTRAN77 is
selected
5762 if test "X$ac_fcompile" = "X" ; then
5763 ac_fcompile='${F77-f77} -c $FFLAGS conftest.f 1>&5'
5764 fi
5765 if { (eval echo "$as_me:$LINENO: \"$ac_fcompile\"") >&5
5766 (eval $ac_fcompile) 2>&5
5767 ac_status=$?
5768 echo "$as_me:$LINENO: \$? = $ac_status" >&5
5769 (exit $ac_status); } && test -s conftest.o ; then
5770 mv conftest.o fconftestf.o
5771 else
5772 echo "configure: failed program was:" >&5
5773 cat conftest.f >&5
5774 fi
Based on lines 1619 and 5763, I don't see how (unless $FROM_MPICH2 isn't
set) the compile could be done correctly. In fact, that is the case. When
I use the info at the tops of tests/mpi/config.log to manually run
configure, it works fine. When I add "FROM_MPICH2=yes ..." to the start,
it no longer works.
I added a call to "env" to the generated configure script, so I know that
FROM_MPICH2 is set. mpich2/tests/mpi/configure* doesn't have a single
reference to MPICH2LIB_FFLAGS.
What am I missing?
Thanks in advance,
Joe Ratterman
Joseph Ratterman/Rochester/IBM at IBMUS
Sent by: owner-mpich2-dev at mcs.anl.gov
03/25/08 10:44 AM
Please respond to
To
cc
Subject
Re: [mpich2-dev] Announcing the availability of MPICH2-1.0.7rc2
I changed all "?FLAGS=" to "MPICH2LIB_?FLAGS=", and "MPI_?FLAGS=" to
"?FLAGS=". Now the configure commands look like this. They both have
"-fno-underscoring", so they both get the same right answer.
build/mpich2/dcmf/config.log:273:configure:6471: checking for Fortran 77
name mangling
build/mpich2/dcmf/config.log-274-configure:6496:
/bgsys/drivers/DRV120_2008-080320P/ppc/gnu-linux/bin/powerpc-bgp-linux-gfortran
-c -Wall -fno-underscoring -g -Wall -O3 -mcpu=450fp2 -mstrict-align
-fno-strict-aliasing -fno-underscoring conftest.f 1>&5
build/mpich2/dcmf/test/mpi/config.log:473:configure:5734: checking for
Fortran 77 name mangling
build/mpich2/dcmf/test/mpi/config.log-474-configure:5759:
-c -Wall -fno-underscoring conftest.f 1>&5
It also appears to be adding the correct flags to the compiler scripts.
Thanks for your help!
Joe Ratterman
Pavan Balaji <balaji at mcs.anl.gov>
03/24/08 09:58 PM
Please respond to
To
cc
Subject
Joe,
The flags definitions have changed a bit since 1.0.7rc1. The previous
usage of the flags were causing duplication of flags for the MPICH2 test
suite. If you want to just compile MPICH2 with some flags, and not have
them reflect in mpif77, etc., you should set MPICH2LIB_FFLAGS to these
flags. Here's the usage:
FFLAGS --> used to compile MPICH2 and gets appended to mpif77
MPICH2LIB_FFLAGS --> only used to compile MPICH2
MPI_FFLAGS, etc., are deprecated.
-- Pavan
On 03/24/2008 08:26 PM, Joseph Ratterman wrote:
> We downloaded the RC2 release and merged it into our code base. When
> building the tests, we found that the Fortran underscoring in the main
> MPICH2 code did not match the settings in the tests directory. This
> caused the build to fail.
> We set our FFLAGS with these options:
> FFLAGS='-g -Wall -O3 -mcpu=450fp2 -mstrict-align -fno-strict-aliasing
> -fno-underscoring'
> MPI_FFLAGS='-Wall -fno-underscoring'
> The detailed analysis is below, but the problem was in the
> mpich2/test/mpi/configure.in file, which blanked the FFLAGS variable
> out. This doesn't make sense for us, since we want to have *fewer*
> flags in the generated mpif77 scripts than are used to compile the
> objects. The test-compile in configure is done with the raw gfortran
> program, so it needs the flags to get the expected answer. Later, the
> tests directory is built with the mpif77 script that does include the
> "-fno-underscoring" option and the Fortran object files have fewer
> underscores than the c objects. Therefore, the Fortran tests that mixed
> c and Fortran language objects failed to match up correctly.
> What was the reason for this change--is it needed on some system? Other
> than our solution of removing the new lines from the configure file, do
> you have a "correct" way for us to solve the build error?
> Looking at the config.log files from the two directories, it seems that
> the FFLAGS variable is missing in the tests dir.
> ./build/mpich2/dcmf/config.log:257:configure:6471: checking for Fortran
> 77 name mangling
> ./build/mpich2/dcmf/config.log-258-configure:6496:
> -c -g -Wall -O3 -mcpu=450fp2 -mstrict-align -fno-strict-aliasing
> ./build/mpich2/dcmf/test/mpi/config.log:452:configure:5740: checking for
> ./build/mpich2/dcmf/test/mpi/config.log-453-configure:5765:
> -c conftest.f 1>&5
> After looking through the changes, This appears to be the problem.
> After removing the added lines, the test is run correctly and gets the
> expected result.
> diff --git a/lib/mpi/mpich2/test/mpi/configure.in
> b/lib/mpi/mpich2/test/mpi/configure.in
> index 9f57971..9542183 100644
> --- a/lib/mpi/mpich2/test/mpi/configure.in
> +++ b/lib/mpi/mpich2/test/mpi/configure.in
> @@ -123,6 +123,14 @@ if test "$enable_threads" = "multiple" ; then
> threadsdir="threads"
> fi
> +# If it is building with MPICH2, set xFLAGS to null, as mpiXX contains
> xFLAGS.
> +if test "$FROM_MPICH2" = "yes" ; then
> + CFLAGS=""
> + CXXFLAGS=""
> + FFLAGS=""
> + F90FLAGS=""
> +fi
> PAC_LOAD_BASE_CACHE
> PAC_VPATH_CHECK()
> This is the code that generates the test compile commands shown at the
top:
> AC_DEFUN(PAC_PROG_F77_NAME_MANGLE,[
> AC_CACHE_CHECK([for Fortran 77 name mangling],
> pac_cv_prog_f77_name_mangle,
> # Check for strange behavior of Fortran. For example, some FreeBSD
> # systems use f2c to implement f77, and the version of f2c that they
> # Eventually, we want to be able to override the choices here and
> # force a particular form. This is particularly useful in systems
> rm -f conftest*
> return
> end
> EOF
> # This is the ac_compile line used if LANG_FORTRAN77 is selected
> ac_fcompile='${F77-f77} -c $FFLAGS conftest.f 1>&AC_FD_CC'
> fi
> *Pavan Balaji <balaji at mcs.anl.gov>*
> 03/21/08 07:32 PM
> Please respond to
> To
> mpich2-dev at mcs.anl.gov, mpich-discuss at mcs.anl.gov,
> mvapich-core at cse.ohio-state.edu, Edric.Ellis at mathworks.co.uk,
> mpich-ms at mcs.anl.gov, dcmf at lists.anl-external.org, knaak at cray.com,
> seppo at totalviewtech.com, yann.kalemkarian at bull.net, Satish Balay
> <balay at mcs.anl.gov>, Dinesh Kaushik <kaushik at mcs.anl.gov>,
> mpi-users at mcs.anl.gov
> cc
> mpich2-core at mcs.anl.gov
> Subject
MPICH2-1.0.7rc2
> Hi all,
> The second release candidate for the next release of MPICH2 (1.0.7) is
> available from
http://www.mcs.anl.gov/research/projects/mpich2/downloads/tarballs/mpich2-1.0.7rc2.tar.gz
> Please try it out and let us know if you encounter any problems. The
> major changes since 1.0.6p1 are highlighted below.
> (Windows binaries are available from
http://www.mcs.anl.gov/research/projects/mpich2/downloads/tarballs/mpich2-1.0.7rc2-win32-ia32.msi
> and
http://www.mcs.anl.gov/research/projects/mpich2/downloads/tarballs/mpich2-1.0.7rc2-win64-x86-64.msi
> Regards,
> The MPICH2 Team
> Main changes in 1.0.7
> # OVERALL: Initial ROMIO device for BlueGene/P (the ADI device is also
> added but is not configurable at this time).
> # OVERALL: Major clean up for the propagation of user-defined and
> other MPICH2 flags throughout the code.
> # OVERALL: Support for STI Cell Broadband Engine.
> # OVERALL: Added datatype free hooks to be used by devices
independently.
> # OVERALL: Added device-specific timer support.
> # OVERALL: make uninstall works cleanly now.
> # ROMIO: Support to take hints from a config file
> # ROMIO: more tests and bug fixes for nonblocking I/O
> # PM/PMI: Added support to use PMI Clique functionality for process
> managers that support it.
> # PM/PMI: Added SLURM support to configure to make it transparent to
> users.
> # PM/PMI: SMPD Singleton Init support.
> # WINDOWS: Fortran 90 support added.
> # SCTP: Added MPICH_SCTP_NAGLE_ON support.
> # MPE: Updated MPE logging API so that it is thread-safe (through
> global mutex).
> # MPE: Added infrastructure to piggyback argument data to MPI states.
> # DOCS: Documentation creation now works correctly for VPATH builds.
> # Many other bug fixes, memory leak fixes and code cleanup. A full
> list of changes is available using:
> svn log -r100:HEAD
> https://svn.mcs.anl.gov/repos/mpi/mpich2/branches/release/MPICH2_1_0_7
> Pavan Balaji
> http://www.mcs.anl.gov/~balaji
Pavan Balaji
URL: <https://lists.mcs.anl.gov/mailman/private/mpich2-dev/attachments/20080326/30066871/attachment.htm>
More information about the mpich2-dev
