[mpich2-dev] [PATCH 1/1] changes to pass testcases when MPI_Aint is 8-byte but (void *) is 4-byte
Douglas Miller
dougmill at us.ibm.com
Tue Mar 25 13:57:26 CDT 2008
Turns out, this must be "(kind=mpi_address_kind)" in order to work for both
cases, 8-byte and 4-byte AINT. So disregard this second (re)patch.
sorry for the extra e-mail.
Douglas Miller BlueGene Messaging Development
IBM Corp., Rochester, MN USA Bldg 030-2 C214
dougmill at us.ibm.com Douglas Miller/Rochester/IBM
Douglas
Miller/Rochester/
IBM at IBMUS To
Sent by: mpich2-dev at mcs.anl.gov
owner-mpich2-dev@ cc
mcs.anl.gov
Subject
Re: [mpich2-dev] [PATCH 1/1]
03/25/2008 10:29 changes to pass testcases when
AM MPI_Aint is 8-byte but (void *) is
4-byte
Please respond to
l.gov
I now see that (kind=mpi_address_kind) is a F90 construct, so have another
way of fixing the shpositionf testcase. There is commented-out code that
got the type extent into an intermediate value and then assigned it to the
fileintsize variable. Re-instating that commented-out code does fix the
problem when MPI_Aint is 8-byte and (void *) is 4-byte.
diff --git a/lib/mpi/mpich2/test/mpi/f77/io/shpositionf.f
b/lib/mpi/mpich2/test/mpi/f77/io/shpositio
index 6e24c73..6ac1996 100644
--- a/lib/mpi/mpich2/test/mpi/f77/io/shpositionf.f
+++ b/lib/mpi/mpich2/test/mpi/f77/io/shpositionf.f
@@ -7,7 +7,7 @@ C
implicit none
include 'mpif.h'
integer comm, fh, r, s, i
- integer(kind=mpi_address_kind) fileintsize
+ integer fileintsize
integer errs, err, ierr
character *(100) filename
include 'iooffset.h'
@@ -31,10 +31,10 @@ C Try writing the file, then check it
endif
C
C Get the size of an INTEGER in the file
- ! call mpi_file_get_type_extent( fh, MPI_INTEGER, offset, ierr )
- ! fileintsize = offset
- call mpi_file_get_type_extent( fh, MPI_INTEGER,
- & fileintsize, ierr )
+ call mpi_file_get_type_extent( fh, MPI_INTEGER, offset, ierr )
+ fileintsize = offset
+C call mpi_file_get_type_extent( fh, MPI_INTEGER,
+C & fileintsize, ierr )
C
C We let each process write in turn, getting the position after each
C write
Douglas
Miller/Rochester/
IBM at IBMUS To
mcs.anl.gov
Subject
03/24/2008 03:09 pass testcases when MPI_Aint is
PM 8-byte but (void *) is 4-byte
Please respond to
l.gov
Changes to make mpich tests pass for 8byte_aint.
1. In MPI_Win_get_attr changed size of output pointer to match interface.
2. MPID_Type_create_pairtype and MPID_Type_struct changes internal
variables from int to MPI_Aint to avoid problems when casting into
new->element_size (although, this may only require removal of the
unsigned cast which ruined the -1 special-value).
3. In testcase shpositionf change variable fileintsize to proper size
for the MPI call mpi_file_get_type_extent parameter.
diff --git a/lib/mpi/mpich2/src/mpi/attr/win_get_attr.c
b/lib/mpi/mpich2/src/mpi/attr/win_get_attr.c
index 958d193..4e09a44 100644
--- a/lib/mpi/mpich2/src/mpi/attr/win_get_attr.c
+++ b/lib/mpi/mpich2/src/mpi/attr/win_get_attr.c
@@ -130,7 +130,7 @@ int MPI_Win_get_attr(MPI_Win win, int win_keyval, void
*attribute_val,
#ifdef HAVE_FORTRAN_BINDING
/* Note that this routine only has a Fortran 90 binding,
so the attribute value is an address-sized int */
- MPI_Aint *attr_int = (MPI_Aint *)attribute_val;
+ MPI_Fint *attr_int = (MPI_Fint *)attribute_val;
#endif
*flag = 1;
diff --git
a/lib/mpi/mpich2/src/mpid/common/datatype/mpid_type_create_pairtype.c
b/lib/mpi/mpich2/src/mpid/common/datatype/mpid_type_create_pairtype.c
index 1484b86..ec1c155 100644
--- a/lib/mpi/mpich2/src/mpid/common/datatype/mpid_type_create_pairtype.c
+++ b/lib/mpi/mpich2/src/mpid/common/datatype/mpid_type_create_pairtype.c
@@ -66,8 +66,8 @@ int MPID_Type_create_pairtype(MPI_Datatype type,
MPID_Datatype *new_dtp)
int err, mpi_errno = MPI_SUCCESS;
- int type_size, el_size, alignsize;
- MPI_Aint type_extent, true_ub;
+ int type_size, alignsize;
+ MPI_Aint type_extent, true_ub, el_size;
/* handle is filled in by MPIU_Handle_obj_alloc() */
MPIU_Object_set_ref(new_dtp, 1);
diff --git a/lib/mpi/mpich2/src/mpid/common/datatype/mpid_type_struct.c
b/lib/mpi/mpich2/src/mpid/common/datatype/mpid_type_struct.c
index 2c72b60..0b2f509 100644
--- a/lib/mpi/mpich2/src/mpid/common/datatype/mpid_type_struct.c
+++ b/lib/mpi/mpich2/src/mpid/common/datatype/mpid_type_struct.c
@@ -151,7 +151,8 @@ int MPID_Type_struct(int count,
int i, old_are_contig = 1, definitely_not_contig = 0;
int found_sticky_lb = 0, found_sticky_ub = 0, found_true_lb = 0,
found_true_ub = 0, found_el_type = 0;
- int el_sz = 0, size = 0;
+ MPI_Aint el_sz = 0;
+ int size = 0;
MPI_Datatype el_type = MPI_DATATYPE_NULL;
MPI_Aint true_lb_disp = 0, true_ub_disp = 0, sticky_lb_disp = 0,
sticky_ub_disp = 0;
@@ -214,7 +215,7 @@ int MPID_Type_struct(int count,
int is_builtin =
(HANDLE_GET_KIND(oldtype_array[i]) == HANDLE_KIND_BUILTIN);
MPI_Aint tmp_lb, tmp_ub, tmp_true_lb, tmp_true_ub;
- int tmp_el_sz;
+ MPI_Aint tmp_el_sz;
MPI_Datatype tmp_el_type;
MPID_Datatype *old_dtp = NULL;
@@ -231,8 +232,8 @@ int MPID_Type_struct(int count,
MPID_DATATYPE_BLOCK_LB_UB((MPI_Aint)(unsigned
long)(blocklength_array[i]),
displacement_array[i],
0,
- (MPI_Aint)(unsigned long)tmp_el_sz,
+ tmp_el_sz,
+ tmp_el_sz,
tmp_lb,
tmp_ub);
tmp_true_lb = tmp_lb;
@@ -359,7 +360,7 @@ int MPID_Type_struct(int count,
new_dtp->n_elements = -1; /* TODO */
- new_dtp->element_size = (MPI_Aint)(unsigned long)el_sz;
+ new_dtp->element_size = el_sz;
new_dtp->eltype = el_type;
new_dtp->has_sticky_lb = found_sticky_lb;
index aabea9a..6e24c73 100644
@@ -7,7 +7,7 @@ C
implicit none
include 'mpif.h'
- integer fileintsize
+ integer(kind=mpi_address_kind) fileintsize
More information about the mpich2-dev
