[mpich2-dev] [PATCH 1/1] Issue 4120: Fix attr alignment check from MPI_Aint to long alignment
Dave Goodell goodell at mcs.anl.gov
Mon Mar 24 16:52:29 CDT 2008
On Mar 24, 2008, at 4:12 PM, Jeff Parker wrote:
> On 03/23/2008 04:26 PM, William Gropp wrote:
> "This one is system-specific - some systems will require the
> MPI_Aint alignment.   This should probably be abstracted out and
> set based on the requirements of the system."
> Are you saying that on some systems, "long" is not the size of a
> pointer, whereas "MPI_Aint" is?  Are there really such systems that
> we need to be concerned about?  Standard C specifies that long and
> pointers are the same size.
Do you have a C standard spec section to which you can point me that
guarantees this?  I can't seem to find one.  It happens to be true on
any platform where I've actually paid attention to the type widths,
but I'm pretty sure it's not mandated by the standard.  I think all
that is required is an ordering between the type sizes (sizeof(int)
<=sizeof(long)) and that (sizeof(char)==sizeof(unsigned char)==1) and
that certain types have certain minimum limits which may be greater
on a given platform.
-Dave
More information about the mpich2-dev mailing list
