[mpich2-dev] [PATCH 1/1] Issue 4120: Fix attr alignment check from MPI_Aint to long alignment
William Gropp
gropp at mcs.anl.gov
Sun Mar 23 16:26:48 CDT 2008
This one is system-specific - some systems will require the MPI_Aint
alignment. This should probably be abstracted out and set based on
the requirements of the system.
Bill
On Mar 21, 2008, at 10:14 AM, Jeff Parker wrote:
> In the mpi/attr code, there were checks to ensure the attribute was
> aligned on a void*
> boundary. This check anded the pointer with sizeof(MPI_Aint)-1.
> In the case of an
> MPI_Aint being 8 bytes, this was forcing the attribute to be on an
> 8-byte boundary, when
> in fact a 4-byte boundary would do. Changed the and operation to
> use sizeof(long)-1 instead.
> Signed-off-by: Jeff Parker <jjparker at us.ibm.com>
> lib/mpi/mpich2/src/mpi/attr/attr_get.c | 7 +++++--
> lib/mpi/mpich2/src/mpi/attr/comm_get_attr.c | 7 +++++--
> lib/mpi/mpich2/src/mpi/attr/type_get_attr.c | 7 +++++--
> lib/mpi/mpich2/src/mpi/attr/win_get_attr.c | 9 ++++++---
> 4 files changed, 21 insertions(+), 9 deletions(-)
> diff --git a/lib/mpi/mpich2/src/mpi/attr/attr_get.c b/lib/mpi/
> index 095c979..cc39822 100644
> --- a/lib/mpi/mpich2/src/mpi/attr/attr_get.c
> +++ b/lib/mpi/mpich2/src/mpi/attr/attr_get.c
> @@ -93,8 +93,11 @@ int MPI_Attr_get(MPI_Comm comm, int keyval, void
> *attr_value, int *flag)
> int when the address of a pointer (or an address-sized int)
> should have been used. We can test for this specific
> case. Note that this code assumes sizeof(MPI_Aint) is
> - a power of 2. */
> - if (MPI_VOID_PTR_CAST_TO_MPI_AINT attr_value & (sizeof
> (MPI_Aint)-1)) {
> + a power of 2. Note that this formerly used MPI_Aint for the
> + address sized int, but since this is configurable
> and could
> + be larger than a pointer, we use long for the
> check, since
> + long is expected to be the size of a pointer.*/
> + if (MPI_VOID_PTR_CAST_TO_MPI_AINT attr_value & (sizeof
> (long)-1)) {
> MPIU_ERR_SET(mpi_errno,MPI_ERR_ARG,"**attrnotptr");
> # endif
> diff --git a/lib/mpi/mpich2/src/mpi/attr/comm_get_attr.c b/lib/mpi/
> index ce5c836..b243968 100644
> --- a/lib/mpi/mpich2/src/mpi/attr/comm_get_attr.c
> +++ b/lib/mpi/mpich2/src/mpi/attr/comm_get_attr.c
> @@ -85,8 +85,11 @@ int MPI_Comm_get_attr(MPI_Comm comm, int
> comm_keyval, void *attribute_val, int *
> - a power of 2. */
> - if (MPI_VOID_PTR_CAST_TO_MPI_AINT attribute_val & (sizeof
> (MPI_Aint)-1)) {
> and could
> check, since
> + long is expected to be the size of a pointer. */
> + if (MPI_VOID_PTR_CAST_TO_MPI_AINT attribute_val & (sizeof
> (long)-1)) {
> # endif
> diff --git a/lib/mpi/mpich2/src/mpi/attr/type_get_attr.c b/lib/mpi/
> index 7547bbb..7a41051 100644
> --- a/lib/mpi/mpich2/src/mpi/attr/type_get_attr.c
> +++ b/lib/mpi/mpich2/src/mpi/attr/type_get_attr.c
> @@ -87,8 +87,11 @@ int MPI_Type_get_attr(MPI_Datatype type, int
> type_keyval, void *attribute_val,
> - a power of 2. */
> (MPI_Aint)-1)) {
> and could
> check, since
> (long)-1)) {
> # endif
> diff --git a/lib/mpi/mpich2/src/mpi/attr/win_get_attr.c b/lib/mpi/
> index 5fbef66..921f018 100644
> --- a/lib/mpi/mpich2/src/mpi/attr/win_get_attr.c
> +++ b/lib/mpi/mpich2/src/mpi/attr/win_get_attr.c
> @@ -82,9 +82,12 @@ int MPI_Win_get_attr(MPI_Win win, int
> win_keyval, void *attribute_val,
> /* A common user error is to pass the address of a 4-byte
> - case. Note that this code assumes sizeof(MPI_Aint) is
> - a power of 2. */
> (MPI_Aint)-1)) {
> + case. Note that this code assumes sizeof(long) is
> and could
> check, since
> (long)-1)) {
> # endif
> 1.5.3.7
William Gropp
Paul and Cynthia Saylor Professor of Computer Science
University of Illinois Urbana-Champaign
URL: <https://lists.mcs.anl.gov/mailman/private/mpich2-dev/attachments/20080323/1432be6d/attachment.htm>
More information about the mpich2-dev
