Fw: [mpich2-dev] MPI_Aint testcase development
Michael Blocksome
blocksom at us.ibm.com
Wed Mar 12 16:30:29 CDT 2008
FYI .. in case anyone missed my previous post. :)
Michael Blocksome
Blue Gene Messaging Team Lead
Advanced Systems SW Development
----- Forwarded by Michael Blocksome/Rochester/IBM on 03/12/2008 04:33 PM
owner-mpich2-dev at mcs.anl.gov wrote on 03/10/2008 03:28:37 PM:
> We are also running the test suite included with MPICH.
> A small subset of that is run on every software build (basically,
> everyday) and we generally try to run through the entire thing
> before significant code check-ins.
> Brian Smith
> BlueGene MPI Development
> IBM Rochester
> Phone: 507 253 4717
> smithbr at us.ibm.com
> Michael Blocksome/Rochester/IBM at IBMUS
> Sent by: owner-mpich2-dev at mcs.anl.gov
> 03/10/2008 03:15 PM
> Please respond to
> To
> cc
> Subject
> I'd like to start a discussion about MPI_Aint testcase development.
> IBM is running the following test suites as each new internal
> development builds become available:
> 1. Intelanl2006
> 2. SKAMPI5
> 3. POKMPISYS
> 4. POKMPIFVT
> What is missing from this list are *targeted* tests for the MPI_Aint
> problem. The only known test (to my knowledge) that hits the problem
> is the b_eff_io program .. yet even this test was not written
> specifically to the MPI_Aint problem.
> Digging through my inbox, I found this from a summary email sent by
> Bryan Hartlen (IBM) on 2/19:
> ROMIO issue:
> The Plan
> 1) Both IBM and ANL agree that the best way to proceed is to use
> what was originally called option B (recasting)
> 2) Both IBM and ANL agree that IBM will assume the lead for
> implementing the change (making the change(s) as required, testing
> and releasing)
> 3) Both IBM and ANL agree that IBM's effort above would benefit from
> any test case development that ANL would be willing to provide.
> 4) Both IBM and ANL agree that IBM's scheduled release for this work
> in the V1R2 release cycle (May 16) is acceptable.
> 5) Both IBM and ANL would like DOE's agreement that this plan above
> is sufficient to remove the ROMIO issue as a gate to starting 500T
acceptance
> In regards to item #3, is ANL able to write testcase code for this
> problem, given your knowledge and understanding of the code paths
> involved? Specifically, what code paths should we consider for test
> case development?
> Let's discuss on this mailing list the targeted tests that need to
> be developed in order to fully test the solution to the MPI_Aint
problem.
> Thanks!
> Michael Blocksome
URL: <https://lists.mcs.anl.gov/mailman/private/mpich2-dev/attachments/20080312/12456f6e/attachment.htm>
More information about the mpich2-dev
