[mpich2-dev] MPI_Dims_create specification question
William Gropp wgropp at illinois.edu
Fri Jun 20 10:57:12 CDT 2008
We should bring this up in the MPI Forum - this interpretation is
clearly at odds with the rationale for virtual topologies at the
beginning of this chapter.   I believe that the intent was for this
requirement to be "subject to the constraints of underlying physical
topology".
Bill
On Jun 20, 2008, at 10:36 AM, Joe Ratterman wrote:
> The system that we are building has a Cartesian network layout, so
> we want to optimize the results of the MPI_Dims_create() function
> to most closely reflect the physical layout of the nodes on the
> network.  Recently, we had a bug report from a customer who noted
> that when running on 8 nodes (an example), MPI_Dims_create(3, [0,
> 0, 0]) doesn't always return [2,2,2].  They consider this an error
> and quote the spec.
> Looking at the spec (latest 2.1 version : http://www.hlrs.de/
> organization/par/services/models/mpi/mpi21/doc/mpi-
> report-2.1draft-2008-06-13.pdf  username and password "mpi21") on
> page 247, the customer appears to be correct.  There is no
> indication that we are allowed to attempt to make the results
> reflect the HW.  Beyond the "must" requirements, there is this one
> more: "The dimensions are set to be as close to each other as
> possible, using an appropriate divisibility algorithm."  Why is
> there no mention of the physical HW?
> Thanks,
> Joe Ratterman
> jratt at us.ibm.com
William Gropp
Paul and Cynthia Saylor Professor of Computer Science
University of Illinois Urbana-Champaign
URL: <https://lists.mcs.anl.gov/mailman/private/mpich2-dev/attachments/20080620/65e9841a/attachment.htm>
More information about the mpich2-dev mailing list
