[mpich2-dev] Apparent bypass of correct macros in collective operation code
    Joe Ratterman
    jratt at us.ibm.com
    Thu Jul 10 20:47:19 CDT 2008
I was recently doing some thread hacking, and I found that some of my
changes where causing a problem in the collective operation C files:
mpich2/src/mpi/coll/op*.c
Specifically, this sort of code was a problem since I got rid of the
op_errno field in the MPICH_PerThread object.
https://svn.mcs.anl.gov/repos/mpi/mpich2/trunk/src/mpi/coll/opbor.c
   165      default: {
   166          MPICH_PerThread_t *p;
   167          MPIR_GetPerThread(&p);
   168          p->op_errno = MPIR_Err_create_code( MPI_SUCCESS,
MPIR_ERR_RECOVERABLE, FCNAME, __LINE__, MPI_ERR_OP,
"**opundefined","**opundefined %s", "MPI_BOR" );
   169          break;
   170      }
I think that there are macros to do this, as seen in the allreduce.c file
(extra lines deleted):
   117      MPIU_THREADPRIV_DECL;
   126      MPIU_THREADPRIV_GET;
   158          MPIU_THREADPRIV_FIELD(op_errno) = 0;
   473          if (MPIU_THREADPRIV_FIELD(op_errno))
   474              mpi_errno = MPIU_THREADPRIV_FIELD(op_errno);
With the default macros, that basically does the same thing, but I didn't
have to change the .c file--only the header files.  The same thing happens
in errutil.c
https://svn.mcs.anl.gov/repos/mpi/mpich2/trunk/src/mpi/errhan/errutil.c
   156  /* These routines export the nest increment and decrement for use in
ROMIO */
   157  void MPIR_Nest_incr_export( void )
   158  {
   159      MPICH_PerThread_t *p;
   160      MPIR_GetPerThread(&p);
   161      p->nest_count++;
   162  }
   163  void MPIR_Nest_decr_export( void )
   164  {
   165      MPICH_PerThread_t *p;
   166      MPIR_GetPerThread(&p);
   167      p->nest_count--;
   168  }
I really think that these places should be using the existing macros to
handle the work.
Comments?
Joe Ratterman
jratt at us.ibm.com
URL: <https://lists.mcs.anl.gov/mailman/private/mpich2-dev/attachments/20080710/a12cfbd7/attachment.htm>
More information about the mpich2-dev
