[MPICH2-dev] running out of fd's?
Rob Ross rross at mcs.anl.gov
Wed Jan 30 16:01:46 CST 2008
nice. i don't see it anywhere in this email thread, but "ulimit -n" on
my macbook does come back with 256. good guess :)? -- rob
On Jan 30, 2008, at 3:46 PM, Dave Goodell wrote:
> If his ulimit is set to 256, then it makes perfect sense that he
> would run out of fd's at anything much higher than 75.  gforker
> probably uses 3 fd's per process (stdin,stdout,stderr).
> floor(256/3)=85, so I would expect to see a problem in the
> transition from 84->85 processes (or maybe a little lower due to the
> 3 fd's for gforker's own stdio).
> In fact, I just tested it, and on my linux box (with "ulimit -n
> 256") I hit the error at 84 processes.
> -Dave
> On Jan 30, 2008, at 3:01 PM, Rob Ross wrote:
>> i guess what i was getting at was that it seems to me that at 100
>> processes he wouldn't be hitting the limit?
>> there's a tool called "lsof" that can be used to look at open files
>> for a specific process; you could use this to see what's going on
>> with the mpd.
>> rob
>> On Jan 30, 2008, at 2:47 PM, Brian R. Toonen wrote:
>>> Nick,
>>> The maximum number of file descriptors per process on your machine
>>> is 10240
>>> and the maximum number for all processes is 12288.  These numbers
>>> were
>>> obtained using the following command.
>>> % sysctl -a | grep maxfiles
>>> kern.exec: unknown type returned
>>> kern.maxfiles = 12288
>>> kern.maxfilesperproc = 10240
>>> kern.maxfiles: 12288
>>> kern.maxfilesperproc: 10240
>>> Assuming you are using (t)csh as your shell, you can increase your
>>> limit per
>>> process to the maximum by adding "limit descriptors 10240" to
>>> your .cshrc
>>> file.  If you use (ba)sh, then adding "ulimit -n 10240" to
>>> your .profile
>>> should do the trick.
>>> --brian
>>> |-----Original Message-----
>>> |From: owner-mpich2-dev at mcs.anl.gov [mailto:owner-mpich2-dev at mcs.anl.gov
>>> ] On
>>> |Behalf Of Rob Ross
>>> |Sent: Wednesday, January 30, 2008 13:53
>>> |To: Darius Buntinas
>>> |Cc: Nicholas Karonis; mpich2-dev at mcs.anl.gov; Brian Toonen
>>> |Subject: Re: [MPICH2-dev] running out of fd's?
>>> |default socket max is i think 1024? -- rob
>>> |On Jan 30, 2008, at 1:26 PM, Darius Buntinas wrote:
>>> |> I bet it's gforker.  It creates O(N) sockets for stdio, etc.  Try
>>> |> mpd and see if that helps.
>>> |> -d
>>> |> On 01/30/2008 01:06 PM, Nicholas Karonis wrote:
>>> |>> Hi,
>>> |>> I just installed MPICH2-1.0.6 on Mac OS X 10.5.1 (i.e.,
>>> Leopard).
>>> |>> I configured it with the gforker and it was all compiled using
>>> |>> Gnu's C and C++ compilers that came with the developer tools
>>> |>> on the Mac OS X disk.
>>> |>> The build seem to go OK and so I tried testing it with a small
>>> |>> ring program (source at bottom).  When I run the ring with -np
>>> 75
>>> |>> all is OK but when I increase it to 100 I get an error message:
>>> |>> /* running with 75, all OK */
>>> |>> mpro% mpiexec -np 75 ring
>>> |>> nprocs 75 received 75
>>> |>> /* attempting to run with 100, problem :-( */
>>> |>> mpro% mpiexec -np 100 ring
>>> |>> Error in system call select: Bad file descriptor
>>> |>> mpro%
>>> |>> Any suggestions?
>>> |>> Thanks in advance,
>>> |>> Nick
>>> |>> --- app source
>>> |>> mpro% cat ring.c
>>> |>> #include "mpi.h"
>>> |>> #include <stdio.h>
>>> |>> #include <stdlib.h>
>>> |>> int main(int argc, char *argv[])
>>> |>>    int nprocs, myid;
>>> |>>    int val;
>>> |>>    MPI_Status st;
>>> |>>    MPI_Init(&argc, &argv);
>>> |>>    MPI_Comm_size(MPI_COMM_WORLD, &nprocs);
>>> |>>    if (nprocs > 1)
>>> |>>    MPI_Comm_rank(MPI_COMM_WORLD, &myid);
>>> |>>    if (myid == 0)
>>> |>>        val = 1;
>>> |>>        MPI_Send(&val, 1, MPI_INT, 1, 0, MPI_COMM_WORLD);
>>> |>>        MPI_Recv(&val, 1, MPI_INT, nprocs-1, 0, MPI_COMM_WORLD,
>>> &st);
>>> |>>        printf("nprocs %d received %d\n", nprocs, val);
>>> |>>    else
>>> |>>        MPI_Recv(&val, 1, MPI_INT, myid-1, 0, MPI_COMM_WORLD,
>>> &st);
>>> |>>        val ++;
>>> |>>        MPI_Send(&val, 1, MPI_INT, (myid+1)%nprocs, 0,
>>> |>> MPI_COMM_WORLD);
>>> |>>    } /* endif */
>>> |>>    } /* endif */
>>> |>>    MPI_Finalize();
>>> |>>    exit(0);
>>> |>> } /* end main() */
>>> |>> mpro%
More information about the mpich2-dev mailing list
