[mpich2-dev] Fw: 32-bit ROMIO: What is the best solution?
Brian Smith smithbr at us.ibm.com
Fri Feb 29 19:48:05 CST 2008
I was probably over zealous in my statement. I know there are a lot of
MPI_Aint == void * assumptions and some MPI_Aint = int * assumptions.
There are probably no int = int * assumptions since, yes, a 64-bit
compiler should find those. I'll let you know if we find any though. :)
Brian Smith
BlueGene MPI Development
IBM Rochester
Phone: 507 253 4717
"Rajeev Thakur" <thakur at mcs.anl.gov>
02/29/2008 05:42 PM
To
"'William Gropp'" <gropp at mcs.anl.gov>, Brian Smith/Rochester/IBM at IBMUS
cc
<mpich2-dev at mcs.anl.gov>, Bob Cernohous/Rochester/IBM at IBMUS
Subject
RE: [mpich2-dev] Fw: 32-bit ROMIO: What is the best solution?
I'd be surprised if there are any sizeof(int*) == sizeof(int) assumptions,
because compilers on 64-bit systems would have warned about them. But
there could be.
Rajeev
Sent: Friday, February 29, 2008 11:30 AM
To: Brian Smith
Cc: mpich2-dev at mcs.anl.gov; Bob Cernohous; owner-mpich2-dev at mcs.anl.gov
Subject: Re: [mpich2-dev] Fw: 32-bit ROMIO: What is the best solution?
Any place where sizeof(int*) == sizeof(int) is assumed is just broken - if
its easy to separate those out, we'll just apply a fix for those, since
that's needed for any platform and under all conditions. The
sizeof(MPI_Aint) == sizeof(void*) assumption will require more care.
Bill
On Feb 29, 2008, at 11:08 AM, Brian Smith wrote:
That's basically what we are doing. The problem is, there are a large
number of places throughout the code (not just in ROMIO) where there are
casts that assume MPI_Aint == sizeof(void*)==sizeof(int*)==sizeof(int), so
we are walking through all that code and seeing what the casts are doing
and fixing them as appropriate.
William Gropp
Paul and Cynthia Saylor Professor of Computer Science
University of Illinois Urbana-Champaign
URL: <https://lists.mcs.anl.gov/mailman/private/mpich2-dev/attachments/20080229/2dfd2976/attachment.htm>
More information about the mpich2-dev mailing list
