[mpich2-dev] about Ticket #337 increment MAX_FINALIZE_FUNC
Rajeev Thakur
thakur at mcs.anl.gov
Tue Dec 23 08:46:52 CST 2008
Thanks. This additional info helps.
Rajeev
> -----Original Message-----
> From: mpich2-dev-bounces at mcs.anl.gov
> [mailto:mpich2-dev-bounces at mcs.anl.gov] On Behalf Of Lisandro Dalcin
> Sent: Tuesday, December 23, 2008 8:45 AM
> To: mpich2-dev at mcs.anl.gov
> Subject: [mpich2-dev] about Ticket #337 increment MAX_FINALIZE_FUNC
> I'm very sorry... I posted this to the wrong address :-(
> ---------- Forwarded message ----------
> From: Lisandro Dalcin <dalcinl at gmail.com>
> Date: Tue, Dec 23, 2008 at 12:42 PM
> Subject: about Ticket #337 increment MAX_FINALIZE_FUNC
> To: mpich2-maint <mpich2-maint at mcs.anl.gov>
> Rajeev, look at this, I hope you will get convinced ;-)
> I've built mpich2-dev like this:
> $ mpich2version
> MPICH2 Version: 1.1a3
> MPICH2 Release date: Unknown, built on Tue Dec 23 10:33:28
> ARST 2008
> MPICH2 Device: ch3:nemesis
> MPICH2 configure: --prefix=/usr/local/mpich2/dev
> --enable-sharedlibs=gcc --enable-g=all
> MPICH2 CC: gcc -g -O2
> MPICH2 CXX: c++ -g -O2
> MPICH2 F77: gfortran -g -O2
> MPICH2 F90: f95 -g -O2
> As you can see, I'm using '--enable-g=all'. Then this surely
> #define's MPICH_DEBUG_HANDLEALLOC. Then the routine
> MPIU_CheckHandlesOnFinalize is being registered many times...
> To confirm this, see the attached file (obtained by running
> the mpi4py testsuite using the 'ddd'
> front-end to gdb)
> Regards,
> Lisandro Dalcín
> Centro Internacional de Métodos Computacionales en Ingeniería
> (CIMEC) Instituto de Desarrollo Tecnológico para la Industria
> Química (INTEC) Consejo Nacional de Investigaciones
> Científicas y Técnicas (CONICET) PTLC - Güemes 3450, (3000)
> Santa Fe, Argentina
> Tel/Fax: +54-(0)342-451.1594
> Lisandro Dalcín
> Santa Fe, Argentina
More information about the mpich2-dev
