[mpich2-dev] Failures on Solaris and standard debug macros
Darius Buntinas
buntinas at mcs.anl.gov
Wed Dec 10 14:22:47 CST 2008
I removed vararg macros from three places. The remaining ones are in
hydra, where it looks like there's an #ifdef to check if they're
supported, and the ib netmod which isn't used anyway.
-d
On 12/10/2008 08:28 AM, William Gropp wrote:
> This morning's failures to compile on Solaris are due to the use of a
> varargs macro definition, which is not universally supported. This was
> used for some debug printfs in the code, as a way to turn them on and
> off easily. This approach, while quick, has several flaws:
> 1) Even in the debug/development version of the code, it requires
> recompilation of the file
> 2) It violates the coding standard that restricts the use of printf
> (this is done to ensure that error messages can be correctly
> internationalized - raw printfs with error messages are incorrect in any
> code that intends to support other languages)
> There is a solution - there are debugging macros that allow the
> informational statements to be turned on and off by class at run time,
> and that can be eliminated entirely in production versions. These are
> used throughout the MPICH2 code and are preferable to the use of raw
> printfs. The are a bit longer, but through the use of editor macros or
> simply saving the template in an editor register, are easy to insert.
> See http://wiki.mcs.anl.gov/mpich2/index.php/Debug_Event_Logging for
> instructions on using these macros.
> William Gropp
> Deputy Director for Research
> Institute for Advanced Computing Applications and Technologies
> Paul and Cynthia Saylor Professor of Computer Science
> University of Illinois Urbana-Champaign
More information about the mpich2-dev
