[mpich2-dev] nesting level warning with MPI_File_preallocate(fh, 0)
Lisandro Dalcin dalcinl at gmail.com
Tue Dec 9 11:27:53 CST 2008
Consider the following Python snipet (sorry, really busy to write
C/C++, I used mpi4py)
from mpi4py import MPI
amode = MPI.MODE_RDWR | MPI.MODE_CREATE | MPI.MODE_DELETE_ON_CLOSE
fh = MPI.File.Open(MPI.COMM_WORLD,
                   '/tmp/datafile', amode,
                   MPI.INFO_NULL)
N = 0
fh.Preallocate(N)
size = fh.Get_size()
assert size == N
fh.Close()
print 'Bye!!!'
Then, when I run the code (1.0.8 and --enable-g=all), I get the following output
Bye!!!
Unexpected value for nesting level = 1
Nest stack is:
	[0] :0
So the warning is likely emitted at MPI_Finalize().
If I try to preallocate sizes larger than 0, then the warning does not appear.
Lisandro Dalcín
Centro Internacional de Métodos Computacionales en Ingeniería (CIMEC)
Instituto de Desarrollo Tecnológico para la Industria Química (INTEC)
Consejo Nacional de Investigaciones Científicas y Técnicas (CONICET)
PTLC - Güemes 3450, (3000) Santa Fe, Argentina
Tel/Fax: +54-(0)342-451.1594
More information about the mpich2-dev mailing list
