[mpich2-dev] MPIR_Localcopy()
Rajeev Thakur
thakur at mcs.anl.gov
Mon Aug 11 21:14:47 CDT 2008
David,
MPIR_Localcopy was implemented in 2002, when ch3 was the only
device, and a local sendrecv did no communication. So the expedient (or
lazy) thing to do was to call a local sendrecv when the datatypes are
noncontiguous. You are right that now it might be better to be less lazy
and call the segment functions directly.
Rajeev
David Gingold wrote:
> MPIR_Localcopy() calls MPIC_Sendrecv(). Is there any reason to do that
> other than, "Wasn't that easy to implement?"
> Yes, my question is a thinly veiled gripe. :^) The side-effects of
> caling Sendrecv threw me for a loop by causing messaging when I least
> expected it. But it seems not so hard to implement Localcopy with
> MPID_Segment_{pack,unpack}(), even in the both non-contiguous case.
> Wouldn't that be better?
> -dg
More information about the mpich2-dev
